Local Time 21:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : webmite based watering system controller
trevor j
Posted: 10:51am 30 Aug 2023
Firstly. Well done Geoff Graham on a fantastic project. My question is having put a new Api key into the General settings , there is no response when l click on test email.
Any ideas would be appreciated. Ps l'm currently running windows 10.
Chopperp
Posted: 11:26am 30 Aug 2023
Hi Trevor
Welcome to TBS
I saw this post
Don't know if it is applicable or not.
Brian
ChopperP
Posted: 11:27am 30 Aug 2023
It does work, so the problem is in discovering why it does not work for you and to help with that you need to provide a lot more information.
First off, can you confirm that you created a SendGrid account, then used that to generate the key.  How many characters are in the key that you entered?  It should be a 69 character string starting with SG.  I have just done a quick test with V1.1 of the firmware and I can confirm that with a malformed key the email test fails and eventually causes a reboot.  So probably something is wrong with your key
I have a new version of the firmware due for release in the next day or two and in it I hope to change its behaviour with a malformed key.  But that will not fix your issue.
Edited 2023-08-30 22:18 by Geoffg
