Local Time 00:21 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Possible bug in MID$?
cosmic frog
Posted: 08:23pm 23 Aug 2023
I may have found a bug in MID$, although it's probably more to do whith something I have done wrong.
I've tracked it down to the example program below.
It simply scrolls a message (which can change) held in mes$. It is this changing of mes$ which causes the program to lose track of the length of Len(m$).
The program runs as it should for a few cycles but then m$ goes to zero and xx counts to 256 which causes the error.
[13] m$=Mid$(mes$,xx,16)
Error : 256 is invalid (valid is 1 to 255)
Any thoughts will be welcome.
PicoMite MMBasic Version 5.07.08b11
OPTION SYSTEM SPI GP2,GP3,GP4
OPTION AUTORUN ON
OPTION LCDPANEL ILI9341, PORTRAIT,GP11,GP12,GP13
OPTION SDCARD GP5
OPTION AUDIO GP0,GP1, ON PWM CHANNEL 0
SetTick 150,call_scroll,1
Print @(10,10);"Len(mes$)=";Len(mes$);"  Len(m$)=";Len(m$);"   xx=";xx;"  "
Loop
Sub call_scroll
tim=tim+1:If tim=80 Then tim=0
If tim=1 Then mes$="           This is message one  "
If tim=48 Then mes$="This is message two "
xx=xx+1:If xx=Len(mes$) Then xx=1
m$=Mid$(mes$,xx,16)
Print m$
End Sub
Thanks.
Dave.
Posted: 08:57pm 23 Aug 2023
Your xx keeps counting to 256, which is too large.
Looks like a program bug.
Before that it gets bigger than the length of mes$ so mid$ returns "" (zero-length string).
Maybe a 2nd bug...
Edited 2023-08-24 06:59 by JohnS
Posted: 08:59pm 23 Aug 2023
xx=xx+1:If xx >= Len(mes$) Then xx=1
That should fix it.
cosmic frog
Posted: 07:22am 24 Aug 2023
  TassyJim said  xx=xx+1:If xx >= Len(mes$) Then xx=1
That should fix it.
Thanks Jim. That seems to have fixed it.
