Local Time 00:21 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picomite vga  problem
Plasmamac
Posted: 08:11pm 21 Aug 2023
PicoMiteVGA MMBasic Version 5.07.08b10
OPTION KEYBOARD US
using Tera term  for paste the code below  press F1 for save  , F2 for run
mmbasic spits an error
[149] Data "93806","68E09","7280A","B3106"
Error : Expected a number
type edit
the display size is changed
type option list
> option list
OPTION KEYBOARD US
OPTION DISPLAY 20, 40
hmm no option Display in the code ,looks like a parser bug
MODE 2
'Init all
Dim integer f,n,oc,wx,wy,l,r,obj(10,10) 'moving Object Vars
'1 Bert, 2 RBall, 3 GBall, 4 Coily,
'5 WrongWay,6 Ugg, 7 Slick 8 Sam, 9 Disc
Dim cl%(15):Restore colors:For f=1 To 15:Read cl%(f):Next
Dim sw%(8)=(0,3,5,6,7,5,4,2,0),sp$
FRAMEBUFFER layer
FRAMEBUFFER write l
CLS cl%(5)
FRAMEBUFFER write n
Restore qb1
For n=1 To 26
Read wx,wy
For y=0 To wy-1
Read sp$:sp$=expand$(sp$)
For x=0 To wx-1
Pixel x,y,cl%(Val("&H"+Mid$(sp$,x+1,1)))
Next x
Next y
Sprite read n,0,0,wx,wy:Box 0,0,wx,wy,,0,0
Next n
FRAMEBUFFER write l:CLS
FRAMEBUFFER write n
Dim LC%(8,4,5)
Restore Levels
For l=1 To 8:For r=1 To 4
Read l1$
For n%=1 To 5:LC%(L,R,n%)=Cl%(Val("&H"+Mid$(l1$,n%,1))):Next
Next :Next
'demo
pyra LC%(1,1,1),LC%(1,1,2),LC%(1,1,3)
FRAMEBUFFER write l:CLS :Text 0,0,"DEMO"
For m=1 To 3
qx%=10:qy%=196
For n=1 To 7
jump 1
Pause 300
Next
Box 120,28,16,16,,0,0
Next
FRAMEBUFFER write n
Text 256,0,"Level="+Str$(l)
Text 256,16,"Round="+Str$(r)
pyra LC%(L,R,1),LC%(L,R,2),LC%(L,R,3)
Pause 500
Next : Next
For l=1 To 15:fields cl%(l):Pause 250:Next
x=0:y=0
FRAMEBUFFER write l
For n=1 To 26
Sprite write n,x,y
Sprite write n,x+160,y,1
Inc x,24:If x>=150 Then x=0:Inc y,32
Next
Pause 20000
FRAMEBUFFER write n
CLS
Loop
'end demo
'Interrupt would be called every 40 ms... main Game loop here  (to come)
Sub Mainloop
Local f
For f=1 To 10
'object in this Level/Round?
If Not obj(f,9) Then move_on
'object active?
If Not obj(f,0) Then move_on
'code etc.
move_on:
Next
End Sub
Function expand$(pxl$)
Local n%,nmb%,tmp$,co$
n%=1: Do
If Asc(Mid$(pxl$,n%,1))< 71 Then
tmp$=tmp$+Mid$(pxl$,n%,1)
Else
co$=Hex$(Asc(Mid$(pxl$,n%,1))-71)
Inc n%:nmb%=Val("&H"+Mid$(pxl$,n%,1))
tmp$=tmp$+String$(nmb%+1,co$)
EndIf
Inc n%:Loop Until n%>Len(pxl$)
expand$=tmp$
End Function
Sub jump(dir%)  'For Demo .. has to be included in Main
Local x%,ox%,oy%,of%
FRAMEBUFFER write l
ox%=QX%:oy%=QY%
Select Case dir%
Case 1
For x%=qx% To qx%+15 Step 2
'If of%=1 Then Sprite hide 1
Box x%-2,oy%,16,16,,0,0
Inc qy%,-3
Sprite show 2-(of%=7), x%, qy%-sw%(of%), 2,1
oy%=qy%-sw%(of%)
Inc of%
Pause 40
Next
Inc qx%,16
End Select
End Sub
'Draws the playground in colors 1 (top) 2 (left) and 3 (right)
Sub pyra C1%,c2%,c3%
tx%=112
For y=0 To 6
For n=0 To y:field tx%+32*n,32+24*y,c1%:block tx%+32*n,40+24*y,c2%,c3%:Next
Inc tx%,-16
Next
End Sub
'------- to recolor just the Top
Sub Fields c1%
tx%=112
For y=0 To 6
For n=0 To y:field tx%+32*n,32+24*y,c1%:Next
Inc tx%,-16
Next
End Sub
Sub field x,y,c
Triangle x,y+8,x+16,y,x+16,y+16,c,c
Triangle x+32,y+8,x+16,y,x+16,y+16,c,c
End Sub
Sub Block x,y,c1,c2
'left
Triangle x,y,x+16,y+8,x,y+16,c1,c1
Triangle x,y+16,x+16,y+8,x+16,y+24,c1,c1
'right
Triangle x+17,y+8,x+32,y,x+32,y+16,c2,c2
Triangle x+17,y+8,x+17,y+24,x+32,y+16,c2,c2
End Sub
colors:
Data RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED)
Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE),RGB(MYRTLE)
Data RGB(COBALT) ,RGB(MIDGREEN),RGB(CERULEAN),RGB(RUST)
Data RGB(FUCHSIA),RGB(BROWN),RGB(LILAC)
'levelcolors
'colors per round:Top, left, right,transition,target
Levels:
Data "98E62","431B6","E3896","6009E"
Data "36C09","BA807","98E07","6A809"
Data "ACE69","90046","6A84B","531B6"
Data "E3869","28E96","8A8B7","6A1B4"
Data "28E96","B3146","E3869","E0096"
Data "96C35","7A88B","28E96","6389E"
Data "98E62","E0096","6389E","6A1B4"
field:
Data 0,0,0,0,0,0,0,1,0,0,0,0,0,0,0
Data 0,0,0,0,0,0,1,0,1,0,0,0,0,0,0
Data 0,0,0,0,0,1,0,1,0,1,0,0,0,0,0
Data 0,0,0,0,1,0,1,0,1,0,1,0,0,0,0
Data 0,0,0,1,0,1,0,1,0,1,0,1,0,0,0
Data 0,0,1,0,1,0,1,0,1,0,1,0,1,0,0
Data 0,1,0,1,0,1,0,1,0,1,0,1,0,1,0
'Compressed sprite Data
'always facing left, have to be mirrored when looking to the right
'2nd sprite is the Object jumping
'1 Bert (4 Sprites)
qb1:
Data 16,16
Data "GF","GF"
Data "0CCEG3CCEEG3","4CCEE0K2CCEEG2","4S2EE774CCU200","04S3874S2EE00"
Data "004S2874S2U20","G24CC44C4S2EE0","G344C4S4EE0","G3K2S5EE0","G344CC4S400"
Data "G4K2CC4CCG2","G5K2S2G3","G4K204CG4","G2440C4C44CG3","G4K20044CG2"""
Data 16,16
Data "0CCEG3CCEEG3","4CCEE0K2CCEEG2","4S2EE874CCU200","04S3874S2EE00"
Data "004S2774S2U20","G24CC44C4S2EE0","G344C4S4EE0","G3K2S5EE0","G344CC4S400"
Data "G4K2CC4CCG2","G5K2S2G3","G6400CG4","G54400CG4","G24C004S2G4"
Data "G344C4044CG3","G544G24CG2"
Data 16,16
Data "GF","GF","G7S3G3","G5K4S200","G5884884C440","G5874874CC44","G4EK5CK2"
Data "G2EES344S244","00ES9K2","0ECCK2C4C4C4C44","0C8844044CK40","04884G2K500"
Data "0044G3K4G2","G74004G3","G5CC400S200","G3EC400EEC4G2"
Data 16,16
Data "G7S3G3","G5K4S200","G5774774C440","G5884884CC40","G4E884884CK2"
Data "0044G3K4G2","G74G24G2","G74G24G2","G74G24G2","G5CC400S200","G3EC400EEC4G2"
'BALL red (2 Sprites)
Data 16,12
Data "GF","GF","GF","GF","G5K4G4","G3K8G2","G2K27K600","00K27K80","00K88K20"
Data "00K78K30","G2KA00","G4K6G3"
Data 16,12
Data "GF","GF","G5K4G4","G3K8G2","G2K27K600","00K27K80","00KC0","00K98440"
Data "00K88K20","G2K588K200","G3K8G2","G5K4G4"
'Ball GREEN (2 Sprites)
Data 16,12
Data "GF","GF","GF","GF","GF","GF","G5Q3G5","G3Q7G3","G2Q27Q32AG2"
Data "G2AA7Q42AG2","G2Q62AAG2","G3Q7G3"
Data 16,12
Data "GF","GF","GF","GF","G5Q3G5","G3Q7G3","G2Q27Q5G2","G2AA7Q42AG2"
Data "G2Q72AG2","G2Q522AAG2","G3Q222Q2G3","G5Q3G5"
'MBall Coily Drop (2 Sprites)
Data 16,16
Data "GF","GF","GF","G4L5G4","G2L2V3L2G2","0055F7L700","055F77L80","055F77L80"
Data "55FLC","LB8585","LA85885","0L7O400","00L4885O2G2","G3L488G4","GF","GF"
Data 16,16
Data "G4L5G4","G2L9G2","00L3V3L300","0L2F7L80","L2F77L9","55FLC","LB8585"
Data "LB8585","LA85885","L8O55","0L5885O350","00L6O3500","G2L2O455G2","G4L5G4"
Data "GF","GF"
'Coily 16x32 up (2 Sprites)
Data 16,32
Data "GF","GF","GF","GF","GF","GF","GF","GF","GF","GF","GF","GF","GF","GF","GF"
Data "GF","00FF0V3G6","0FL7G5","0FL8G4","0FL9G3","FLAG3","FL2G4L2G3"
Data "07005500L3G3","0FL8G4","00FL7G4","00L6G6","00F5G65G3","00F55G355G4"
Data "G2FL605G2","G3FL30055G2","GB5G2","GF"
Data 16,32
Data "00FF0FFG8","0FL5G7","0FL5V2G4","0FL8FG3","FLAG3","FL4G3L2G2","055G7L200"
Data "07007G65500","GBF550","G35V2G3F550","00FL5F00F550","0FL200L2005500"
Data "L3FG2L30500","FL2FG3L3G2","0FL2V250L2G2","00FL6055G2","G4L300L200"
Data "GB5500","GBF550","00V6G2F550","0FL700F550","0FL2G2L20L20","0F55G3FL20500"
Data "0FL50L3G2","G45500L3G2","G9L2G2","G9L2G2","G9L2G2","G2FG5L2G2"
Data "G25FG3F55G3","G355V255G4","G555G7"
'Coily 16x32 down (2 Sprites)
Data 16,32
Data "GF","00FF0FF5FG6","0V555FG5","078787L3FG4","05N2L5FG3","L70L2FG2"
Data "L6G255FG2","0L4G355FG2","07007G2L3G3","G2L70FG2","G3L4005FG2","G8F55FG2"
Data "G25G3FL2G3","G35V3L2FG2","G5L405F00","GB5F00","GB5G2"
Data 16,32
Data "00FF0FFG8","0V55G7","07878755V2G4","05N2L5FG3","LBFF00","L5G3L2F00"
Data "0L4G4L2F0","07007G655F0","GC55F","G35V2G455F","00L6FG255F","0L300L2FL2F0"
Data "L3FG4L3F0","0505FG3L3F00","00505V2L4G2","G250L500F00","G4L2G355F0"
Data "GB55F0","GC55F","005V5G355F","0L7FG255F","0L3G35FL3F","0L2G5L3F0"
Data "0LBF00","G4L4G5","GAV200","G9L2F00","G9L2F00","G2FG5L300","G25FG3FL2G2"
Data "G355V255G4","G555G7"
' WrongWay (2 Sprites)
Data 16,16
Data "GF","00L2G45G4","0FFG655G3","F00F005500505G2","F500L600500","0FL805G2"
Data "00F5878755005500","0FF558787L3050","FF57755785005005","0FN3557G6"
Data "FF7788755G6","FFN28755V25500","FF5N288700FG3","0FF55778700FFG2","V477G8"
Data "00V2GA"
Data 16,16
Data "00L2G45G4","V25G65G3","FF0FFG4505500","FG455055G250","FF00L5G2500"
Data "0FL6G2L20","00L27L3055055","0FL37L4G25","V2775575FFG4","0FN3557G6"
Data "FFN4L2G5","FF7887755F5G4","FF57O2770FL200","0FF55787G2FG3","V477G4F500"
Data "00V2GA"
'6 Ugg (2 Sprites)
Data 16,16
Data "G57G8","G3705G8","00700F5G8","G250F550FF00550","G250F05FF500550"
Data "00F500F55F550505","00F55FF5F578L3","00F0L2F57885500","G3L378875G2"
Data "00FFL387L300","0L978500","50L6F775G2","500L5F7FF500","0500L4V20L2"
Data "0050050L4G3","GAL200"
Data 16,16
Data "G47G9","G2705G9","0700F5G9","0050FL20FF00550","7050F005FF500550"
Data "0F5G2FL40585","0FL2FF55F58L3","0F00L3F58L200","G3L2F58L2G2","00FFL900"
Data "0L977500","50L6F775G2","500L5F8FF500","0500L4V20L2","0050050L4G3","GAL200"
'7 Slick (2 Sprites)
Data 16,16
Data "GF","GF","G9EG4","G6E0E00EG2","G5U30EG3","G4EEAEAEG4","G3EAEEAEAEG3"
Data "G27AA7Q2E2G3","G278787AA2A2G2","00A78787A2A22G2","00AN42A22AG2"
Data "00A72272AI3G2","00I7A2G3","G228822AI2G3","G3I6G4","G2I20I2G5"
Data 16,16
Data "G6E0E00EG2","G5U30EG3","G4EEAEAEG4","G3EAEEAEAEG3","G27AA7Q32G3"
Data "G277878AA2A2G2","00A77878A2A2AG2","00AN42AI2G2","00A72272A22A2G2"
Data "002288I5G3","G2288I2A22G3","G3I7G3","G42G222G4","G42G22G5","G42G22G5"
Data "G3I20I2G4"
'8 Sam (2 Sprites)
Data 16,16
Data "GF","GF","G9EG4","G6E0E00EG2","G5U5G3","G4U3AE00E00","G3EAEAAEAEEG2"
Data "G2Q72G3","G287887O4G2","00A87887A2A22G2","002882882AI2G2","00I5AI3G2"
Data "00I9G3","G2288I4G4","G3I6G4","G2I20I2G5"
Data 16,16
Data "G6E0E00EG2","G5U30EG3","G5EAEAE00E00","G3EEAEAEAEEG2","G2Q6E2G3","G2O8G3"
Data "00A87887A2A22G2","002872872AI2G2","00I5AI3G2","00I9G3","G2288I5G3"
Data "G2I7G4","G322G222G4","G42G22G5","G42G22G5","G2I20I2G5"
'9 Disc (4 Sprites)
Data 16,12
Data "GF","G54499G5","G2K6P2G2","0K8P40","K2I34P66","4I66P3M2","3I4M88"
Data "J2I2M6O2","0J4226683O20","G2J483838G2","G53383G5","GF"
Data 16,12
Data "GF","G52244G5","G2I6K2G2","0I8K40","I2M32K69","2M69K3P2","3M4P88"
Data "J2M2P6O2","0J4669983O20","G2J483838G2","G53383G5","GF"
Data 16,12
Data "GF","G56622G5","G2M6I2G2","0M8I40","M2P36I64","6P64I3K2","3P4K88"
Data "J2P2K6O2","0J4994483O20","G2J483838G2","G53383G5","GF"
Data 16,12
Data "GF","G59966G5","G2P6M2G2","0P8M40","P2K39M62","9K62M3I2","3K4I88"
Data "J2K2I6O2","0J4442283O20","G2J483838G2","G53383G5","GF"
Plasma
Posted: 09:39pm 21 Aug 2023
When you change to mode it changes the display to match. Use EDIT 1 to edit in 640x480 if the current mode is 2
Martin H.
Posted: 06:28am 22 Aug 2023
Error : Expected a number...
missing a "," somewere?
Edited 2023-08-22 16:35 by Martin H.
'no comment
IanRogers
Posted: 07:05am 22 Aug 2023
Your first read is 26 numbers.. but you only have 15.
then they are strings.
If I missed something then I apologise.
Note* I really can't read this basic yet.. The syntax is so complex for a basic.
Edited 2023-08-22 17:08 by IanRogers
I'd give my left arm to be ambidextrous
Martin H.
Posted: 07:17am 22 Aug 2023
First it defines and reads the Values of the 15 Colors (plus 0) = 15 Numbers
so far it is correct.
Later the For n=1 To 26 is reading the Sprites but has also set the Pointer to the right lable Restore qb1
The Sprite data after qb1: is stored in 2 numbers(x and y size) and the Sprite Data in compressed form as strings
'no comment
IanRogers
Posted: 07:34am 22 Aug 2023
I have been playing with C64 basic as there are many similarities, but this syntax is a mis mash of several basics with C thrown in.
Don't get me wrong. I'll get there.  I'm trying to port Chess over but the learning curve is way harder than it was for C and Pascal.. LOL..
I do like this platform and I may try the Armite, but I need to get the syntax "in me head" first. I am still playing with writing C libraries and using them. But that kinda defeats the purpose. I have Pico's on the Arduino platform and I can do tons, but this is more..... Nostalgic.
Martin H.
Posted: 08:44am 22 Aug 2023
  IanRogers said  I have been playing with C64 basic as there are many similarities, but this syntax is a mis mash of several basics with C thrown in.
I started with Sinclair Basic ZX81->Spectrum->QL. In addition, there was a little MS Basic on the Dragon32 (similar to that of the PET/C64 only more extensive). Then with GFA on the Atari ST I got rid of the line numbers and in VB & VBA under Windows it became event-oriented.
Even if you use the same Basic Dialect, it is partly hart to translate from one System to another. Like transfering Programs vom CMM to Pico.
That's why I understand if it's not easy to read someone else's source code. I sometimes have trouble understanding my own source codes when they are a few months old.
'no comment
Posted: 09:14am 22 Aug 2023
Commodore BASIC is one on its own, unfortunately. I think if I was to learn BASIC again it's not one I would choose to start with. :) I used to have a C64 and, I'll be honest, it was the only machine I was finally glad to get rid of.
The Atari STFM was a whole new ball game. I loved that machine (lost in a fire, unfortunately). I even considered getting a replacement but even a second hand one was a bit expensive at the time.
For sheer programming fun I still think the old Speccy took some beating. Once you got used to the keyboard system it was surprising how quickly you could churn something out.
I've been converted by MMBasic now though. :)
IanRogers
Posted: 09:30am 22 Aug 2023
  Quote  The Atari STFM was a whole new ball game. I loved that machine (lost in a fire, unfortunately).
I have one here.. I too loved this. I had a really good MIDI Keyboard, loads of fun.
  Quote  That's why I understand if it's not easy to read someone else's source code. I sometimes have trouble understanding my own source codes when they are a few months old.
Yep! Me too I keep forgetting to comment / remark..
  Quote  For sheer programming fun I still think the old Speccy took some beating. Once you got used to the keyboard system it was surprising how quickly you could churn something out.
I think I have most models.. 16k, 48k, original toastrack, +2, + 3 and a piggin QL.
I have a BBC B+ and a A500 with evertyhing. All upstairs.
Now I have Pi's and Pico's doing all this stuff... Tell you what I don't have.. A life.
Posted: 10:08am 22 Aug 2023
hehe....
I'm very familiar with that situation. :)  I too have a collection of ancient machines, including a couple of 19" racks with Nascom-2 systems in them, a pile of Gemini boards intended to go into a 19" rack or three, a pile of ZX81s and various assorted Speccys, a Camputers Lynx and a Mattel Aquarius. That's without the PCs, a smattering of RPis and a box of breeding RP2040 devices. Oh, and a Goldstar MSX. A lot of this stuff has been donated by various people over the years.
