Local Time 00:21 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Adding MMIO RAM On The RP2040
lew247
Posted: 01:43pm 21 Aug 2023
  Quote  The problem
Can you use 8MB of external RAM with RP2040, memory mapped, like real memory?
The Answer
Towards a solution
First of all, how would you boot without persistent memory? I solved this by having both a flash and a RAM onboard. RP2040 only has a single nCS pin for SSI and only a single memory mapped address range, so we'll not be able to use them both. The idea is to boot from flash, copy flash to the start of RAM, and continue running from RAM. How do we make all of this work? It does not take much
the rest is in the article
Posted: 02:37pm 21 Aug 2023
  lew247 said
  Quote  The problem
The Answer
Towards a solution
When I understand correctly using external RAM for variables is not very efficient.
It takes 363 cyles (at 133MHz that is 3usec) to write a single 32 bit value ot RAM.
Block writes are seriously faster (up to 36Mbyte/second whis is around 0.25usec per word). But it is a nice "proof of concept". Nobody thought it could be done, and someone proves...it can be done..
Posted: 03:13pm 21 Aug 2023
This is a "because it's there" project. :) How usable it would be with those restrictions on write speed is something else.
