Local Time 00:22 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PWM setup Anomaly
carlschneider
Posted: 09:40pm 20 Aug 2023
Hi there
Options and version for reference.
WebMite MMBasic Version 5.07.08b11
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 252000
OPTION DISPLAY 41, 140
OPTION WIFI Actiontec1177, **********, PICOE6614103E76
OPTION TCP SERVER PORT 80
OPTION TELNET CONSOLE ON
I had PWM working on GP28 with the following setup
SetPin GP28, PWM6A
Target=50.01
PWM 6,Target, 50
To use the ADC GP26-28 I needed to shift the PWM to another GPIO so I chose GP19 which per v3 WebMite manual Page 9 pinout is PWM1B. The following code refers.
SetPin GP19, PWM1B
Target=50.01
PWM 1, Target, 50
This generates the following error on the console
[21] PWM 1, Target, 50
Error : Pin not set for PWM
The v3 Manual indicates for PWM setup that either channel A or B can be configured for the channels 0 through 8 and in my understanding implies independently, not as a pair or only the A channel of a pair.
If I use the following code
SetPin GP18, PWM1A
Target=50.01
PWM 1, Target, 50
it works just like it should.
As a sanity check I tried
SetPin GP21, PWM2B
Target=50.01
PWM 2, Target, 50
which generates the following error on the console
[21] PWM 2, Target, 50
While the following code
SetPin GP20, PWM2A
Target=50.01
PWM 2, Target, 50
works like it should.
Has anybody else had similar experiences or is this a bug or am I misreading the manual?
Any help would be appreciated.
Cheers Carl
Retirement is tough on Hobbies without a day job
Posted: 10:02pm 20 Aug 2023
Try this:
SetPin GP19, PWM1B
Target=50.01
PWM 1, Target,, 50
The extra coma sends the output to channel B, otherwise it tries to send it to A.
carlschneider
Posted: 10:16pm 20 Aug 2023
  phil99 said
Try this:
SetPin GP19, PWM1B
Target=50.01
PWM 1, Target,, 50
Thanks Phil kept looking right past it and not seeing what I should have. If it was a snake and all that. Your help is much appreciated.
Cheers Carl
