Local Time 00:21 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug  in all PicoMite`s  sub-directory  time stamps !
amigawizard
Posted: 12:33pm 19 Aug 2023
I  'Think !'  this is in  all PicoMite`s
OPTION LIST
WebMite MMBasic Version 5.07.08b11
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 252000
OPTION WIFI ****, ********, PicoW
OPTION TCP SERVER PORT 80
OPTION TELNET CONSOLE ON
> files
A:/testdir
  <DIR>  .
  <DIR>  ..
00:00 00-00-1980       1024  Rxx-1-test.bas
2 directories, 1 file, 512000 bytes free
> ? time$
22:19:57
> ? date$
19-08-2023
> save "a:testdir/web.bas"
> files
A:/testdir
  <DIR>  .
  <DIR>  ..
00:00 00-00-1980       5197  web.bas
2 directories, 2 files, 503808 bytes free
***  files at the  root  ***
> files "a:"
A:/testdir
  <DIR>  .
  <DIR>  ..
> files "a:/"
A:/
  <DIR>  .
  <DIR>  ..
  <DIR>  testdir
00:00 01-01-2000          4  bootcount
21:28 18-08-2023       3584  thermo3.html
21:28 18-08-2023       5248  theruning.bas
3 directories, 3 files, 503808 bytes free
  Wayne  !
Posted: 01:29pm 19 Aug 2023
You will find that it works if the file doesn't previously exist. LittleFS does not update the created timestamp when you overwrite an existing file
amigawizard
Posted: 02:00pm 19 Aug 2023
the  file  saved  in
   "a:testdir/web.bas"
 > save "a:testdir/web.bas"
  is is new !
     Rxx-1-test.bas
    is copyed with   'MMCC' from the PC
  Wayne  !!
Posted: 02:01pm 19 Aug 2023
i.e. the time stamp is a file creation time, not a file update time. :)
Not all file systems support last-open or last-updated times. It's not a bug, just a limitation of the filesystem.
amigawizard
Posted: 02:06pm 19 Aug 2023
Ok  but  "web.bas" is  today`s
   Wayne  !!!
amigawizard
Posted: 02:16pm 19 Aug 2023
It is  date`s & time`s  in the SubDirectorys  only !
   Wayne  !!!!
Posted: 02:30pm 19 Aug 2023
I can't test with that version of MMBasic as I don't have a WebMite.
Your point is that new files, when saved directly into a sub-directory accessed by a path, aren't getting timestamped?
amigawizard
Posted: 03:51pm 19 Aug 2023
PicoMite  to  with a SubDirectory
        Wayne  !!!!!
Posted: 04:18pm 19 Aug 2023
OK found it. What confuses is that if the same filename exists in the route directory the timestamp from that file is shown
The basic problem is that LittleFS doesn't support timestamps at all. It has to be done through a user "attribute" and user attributes don't understand an open file. The I/F to attributes requires a fully qualified pathfilename. i.e. littlefs doesn't understand "current directory" . That is purely a construct that I have created in the CHDIR code to mimic FatFS
Will be fixed in next beta
Edited 2023-08-20 02:21 by matherp
