Local Time 00:22 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : simple ADC Oscilloscope
amigawizard
Posted: 11:07am 17 Aug 2023
Hi All
    adc_test_1.bas
' adc test 1
Dim anaray1!(3000) , anaray2!(3000) , anaray3!(3000)
SetPin 1 , pwm
PWM 0 , 5000 , 55
ADC open 122000 , 2
ADC start anaray1() , anaray2()
Memory
End
  Wayne !
amigawizard
Posted: 12:02pm 17 Aug 2023
use  putty  !
     adc_tirg_6.bas
' adc test 6
Dim anaray1!(4500) , anaray2!(4500) , anaray3!(4500)
SetPin 1 , pwm
SetPin 2 , pwm
'PWM 0 , 500 , 25 , 2
PWM 0 , 50 , 25 , 5
' ADC open 122000 , 2
ADC open 22200 , 2
'Memory
'disp
trig3
dist
Print @(4,430) "        .             .         .  "
Print @(4,430) t1 , t , , anaray2(t) , anaray2(t+99)  , anaray2(t+100) , anaray2(t+101) , , x , anaray1(t)  , anaray1(t+200)
Print t + x ; "   "
End
Sub disp
  For x = 1 To 1255  Step 12
     Print @(x,-(anaray1(x)*30)+150) "*" : Print @(x,-(anaray2(x)*50)+350) "-"
  Next x
End Sub
Sub dist
  For x = 1 To 1350
''      Print @(x,-(anaray1(x+t)*30)+150) "*" : Print @(x,-(anaray2(x+t)*30)+400) "-"
pixel x , -(anaray1(x+t)*30)+150)
pixel x , -(anaray2(x+t)*30)+400)
  Next x
End Sub
Sub trig
  For t = 1 To 2000
'      If anaray1(t) > 2 Then If anaray1(t+1) < 1 Then Exit For
'      If anaray1(t) > 1 Then If anaray1(t+1) < 2 Then Exit For
'      If anaray1(t) < 2 Then If anaray1(t+1) > 1 Then Exit For
'      If anaray2(t) > 1 Then If anaray2(t+1) < 2 Then Exit For
'      If anaray2(t) > 1 Then If anaray2(t+100) < 2 Then Exit For
     If anaray2(t) < 1 Then If anaray2(t+100) > 2 Then Exit For
  Next t
  Print t , "here"
End Sub
Sub trig2
  For t1 = 1 To 2000
     If anaray2(t1) > 1 Then If anaray2(t1+100) < 2 Then Exit For
  Next t1
  For t = t1 To 2000
  Next t
End Sub
Sub trig3
  For t1 = 1 To 2000
     If anaray2(t1) > 1 Then If anaray2(t1+50) < 2 Then Exit For
  Next t1
  For t = t1 To 2000
     If anaray2(t) < 1 Then If anaray2(t+50) > 2 Then Exit For
  Next t
End Sub
End
      Wayne  !!
Posted: 02:50pm 17 Aug 2023
This is what I seen running on a PicoMite with 480x320 ILI9488:
What would I do to see something more interesting?
amigawizard
Posted: 03:15pm 17 Aug 2023
@ Lizby
  pixel x , -(anaray2(x+t)*90)+150)
     and connect  pin1  to pin32
     *90  set the  gain
     F2  rerun   !
    Wayne  !!!
Posted: 03:32pm 17 Aug 2023
Ok, thanks. With that, I get this:
amigawizard
Posted: 04:15pm 17 Aug 2023
@ lizby
      pixel x , -(anaray2(x+t)*gain)+offset)
      pixel x , -(anaray2(x5 +t)*90)+150)
 try     For x = 1 To 480
     Wayne  !!!!
amigawizard
Posted: 12:54pm 22 Aug 2023
this is  to be  run   with  Putty  !
  ch = 32
Sub DoDC CH
''   ADC close
  ch = CH
  SetPin ch , ain
  Tstop = 0
  SetTick 18.1 , tick , 2
  Timer = 0
  mDC
  Print Timer
  Tstop = 2
  SetTick 0 , 0 , 2
'Print  " DC = " ; DC ; " Vdc  "
Print Format$( DC , "    DC = %2.4f  Vdc  " )
End Sub
Sub tick
  Tstop = 1
End Sub
Sub mDC
     nDC = 0
  For n = 1 To 400
     nDC = nDC + Pin(ch)
     If Tstop = 1 Then Exit For
  Next n
  Print DC , nDC , nDC / n , n , Pin(ch)
  DC = (nDC / (n ) )
''   Print
End Sub
    DC Voltage  Meter
     this one remove`s  50 Hz  and  averages  (200+)  samples
       Wayne !!!!!
amigawizard
Posted: 03:42pm 22 Aug 2023
update !!
Sub dcx
ch = 32
SetPin ch , ain
m = 0
Timer = 0
Do While Timer < 19.86  '20 ms
Dc = Dc + Pin(ch)
Inc m
Loop
Print ,, Timer, m
Dc = Dc / m
  Print Dc
End Sub
    Option  F9 "dcx" + chr$(13) + chr$(10)
        Wayne  !!!!!!
