Local Time 00:48 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to become Bytes from the console port .Picomite
Plasmamac
Posted: 07:25pm 16 Aug 2023
Hi , i need to capture a serial stream from the console (usb).
What is the best way to do so?
Thx
Plasma
Posted: 07:45pm 16 Aug 2023
I use PuTTY and turn on logging; captures the output to a file
probably the same method available in whatever flavour of terminal emulator you use
Edited 2023-08-17 05:46 by CaptainBoing
Posted: 09:36pm 16 Aug 2023
putty, terraterm and MMEdit and I think, GFXterm all do capture.
If the data contains non printable bytes such as chr(0), You have to test the options. MMEdit has HEXview for inspecting the data.
If you want anything special, use MMB4W
Posted: 10:47pm 16 Aug 2023
screen does, too (with -L for logging).
