Local Time 21:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite array questions
MarkF
Posted: 03:43am 09 Aug 2023
Hi. For an one dimensional array with numbers for elements, how would I obtain the "lowest positive' element value, excluding zero(0)? Thanks.
Martin H.
Posted: 06:21am 09 Aug 2023
Hi Mark,
If i understand your question right.
Therange of floating point numbers is
1.797693134862316e+308 to 2.225073858507201e-308.
The range of 64-bit integers (whole numbers) that can be manipulated is ± 9223372036854775807.
Mart!n
Edited 2023-08-09 16:38 by Martin H.
'no comment
Posted: 07:38am 09 Aug 2023
Find the max of the array.
Add 10xmax to all numbers that are equal zero or negative.
Find the min of the array
That is your answer.
MarkF
Posted: 07:47am 09 Aug 2023
Thanks Martin and Volhout.
I should have given an example.
One dim array e.g.  (12,0,14.5,3,62)
The lowest element in the array is 0, but I wanted to get 3 instead (the lowest min above zero).
MMBasic function ====> MATH(MIN arrayname()) is a solution.
But it returns 0 if I use it on the above example array. Whereas I would like to get 3.
MATH(MIN arrayname() [,index%])
Perhaps the index can be used, but I don't know how to use it.
-thanks
Edited 2023-08-09 18:38 by MarkF
Posted: 08:51am 09 Aug 2023
Can't think of any way to do this with the MATH commands or functions so you will need to just write a loop
General solution
max = 1.797693134862316e+308 ' or 9223372036854775807 if integer array
for i=bound(array(),0) to bound(array())
 if(array(i)>0 and array(i)<max then max = array(i)
next i
print max
Posted: 10:23am 09 Aug 2023
Not the fastest:
DIM a(4) = (12,0,14.5,3,62)
DO
m = MATH(MIN a(), index%)
IF m = 0 THEN
a(index%) = 100000
ENDIF
LOOP UNTIL m > 0
PRINT index%, m
Make a copy of the array first if you need to retain all elements.
Another way is 'sort' then step through to skip over the zero values.
Posted: 10:39am 09 Aug 2023
Don't reject zero values. Add 0.001 to everything and don't have them to start with. ;)
MarkF
Posted: 01:33pm 09 Aug 2023
Thanks Matt, Jim and Mick .  Jim's example of the MATHS MIN function is very interesting.
- Mark
