Local Time 21:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Webmite Port Command/Function Query
carlschneider
Posted: 03:39am 09 Aug 2023
Hi there
Thanks for accepting me onto the forum.
I hope I'm posting this correctly.
On the Webmite v5.07.07 the Port() function appears not to read pins set to Output.
Port(24,4)=&B1111 has the expected result with SetPin 24, DOUT etc. before hand.
However Print Port(24,4) results in an Error : Invalid input pin.
The Webmite Manual version 3 clearly states "...This function will also return the state of a pin configured as an output..."
Is it just me being stupid or is there something I'm missing?
Any guidance would be appreciated.
Carl
Cheers Carl
Retirement is tough on Hobbies without a day job
Posted: 07:19am 09 Aug 2023
Tested WebMite MMBasic Version 5.07.08b9 and the PicoMite MMBasic Version 5.07.08b9 but got a different result reading individual pins. They both do this.
> setpin 1,dout
> setpin 2,dout
> setpin 4,dout
> setpin 5,dout
> Port(1,4)=&B1111
Error : Invalid output pin
> Port(gp0,4)=&B1111
> ? pin(1)
1
> ? pin(gp1)
1
Reading the pins individually is ok but the Port Function is not.
The command and function seem to need GP numbers.
Edited 2023-08-09 17:38 by phil99
Posted: 07:32am 09 Aug 2023
from the manual PORT function
  Quote  Returns the value of a number of I/O pins in one operation.
'start' is an I/O pin number and its value will be returned as bit 0. 'start'+1 will
be returned as bit 1, 'start'+2 will be returned as bit 2, and so on for 'nbr'
number of bits. I/O pins used must be numbered consecutively and any I/O
pin that is invalid or not configured as an input will cause an error.
The
start/nbr pair can be repeated up to 25 times if additional groups of input pins
need to be added.
This function will also return the state of a pin configured as an output. It
can be used to conveniently communicate with parallel devices like
memory chips. Any number of I/O pins (and therefore bits) can be used
from 1 to the number of on the chip.
See the PORT command to simultaneously output to a number of pins.
The manual has two contradictory phrases. The code is the same across all variants of MMbasic and currently errors on an output. I'll change the code in the next beta and remove the inconsistency in the next manual update
  Quote  Reading the pins is ok but the Port command seems to need GP numbers.
The result you see is correct.
GP0, GP1, GP2, GP3 are consecutive
1,2,4,5 are not
so use either
port(1,2,4,2) or port(gp0,4)
Edited 2023-08-09 17:44 by matherp
Posted: 07:59am 09 Aug 2023
It's never a good idea to use the hardware pin numbers as it breaks compatibility with other platforms. The GPn numbers are what the RP2040 uses so they can be used on any hardware platform that uses that chip. I know it's a little more typing, but it's worth it in the long run. :)
LouisG
Posted: 12:05pm 09 Aug 2023
Hi all,
I've been using pin numbers all along so far and successfully. I understood the concept and reason for GP numbers but they raised question marks. Are they integers? Is it legal to write
FOR i = GP4 TO GP11   when setting pins?
I didn't encounter any examples in the manual though there could be. Also there's nothing under Variables or Integers regarding GP numbers. I will, however, have a fresh look at them in light of Matherp's comments above.
... Louis
Posted: 12:31pm 09 Aug 2023
Not quite that simple.
> for i=4 to 11:setpin (mm.info(pinno ("GP"+Str$(i)))), dout:next
> port(gp4,8)=255
> ? pin(gp4),pin(gp11)
1       1
removed some brackets
> for i=4 to 11:setpin mm.info(pinno "GP"+Str$(i)), dout:next
> port(gp4,8)=255
> for i=4 to 11 : p=mm.info(pinno "GP"+Str$(i)) : ? pin(p), :next
1       1       1       1       1       1       1       1
Edited 2023-08-09 22:52 by phil99
Posted: 12:56pm 09 Aug 2023
Phil,
I don't see what your code proves...  seemingly nothing...
Posted: 01:06pm 09 Aug 2023
  Quote  I don't see what your code proves.
It is how you can set up and/or read/write multiple pins by gpno in a loop
Posted: 04:15pm 09 Aug 2023
Only does one per loop, right?
Nothing wrong with that but what is the point & why two versions?
carlschneider
Posted: 04:43pm 09 Aug 2023
Thank you all for your comments and support, it is truly appreciated.
The benefit to me of the Port command/function is the ability to drive a sequential tap changer on an excess PV diversion to geyser. I have implemented this on an ESP32 about 2 years ago using Visual Studio. My version control leaves somewhat to be desired and the code, compile, upload, run, fix, ... development cycle does not make coming back after 2 years to fix a few non-critical bugs very pleasant. The code, run, fix, ... development cycle on the Webmite is far more preferable. Besides it harks back to my first pukka computer, a Radio Shack TRS-80 with a whole 16K of memory.
The tap changer, a bunch of relays, is in the secondary of a specially wound transformer. To change taps I first have to open all the relays and wait 30ms for the contacts to open - mechanical relays and the joy thereof. A more elegant approach would be to write to the port, wait 30ms, and then write the new tap changer position to the port. The sequence of the tap changer is either up one step or down one step at a time so it would be nice to be able to read the port and bit shift to drive the tap changer. On the ESP32 I've had to implement a loop to open all the relays in sequence and then wait 30ms before setting the correct tap changer pin.
matherp - Thanks for the comments and giving my brain some reprieve :) I look forward to the update. Hopefully the fix will allow the reading of the state of the output pins in parallel.
In my sample i'm using GP18, GP19, GP20 and GP21 specifically because the PIN numbers are sequential. I tried
Print Port(GP18,4) but still get the Error : Invalid input pin.
Changing the DOUT to DIN resulted in the correct parallel read of the 4 pins and an appropriate Print value.
Mixtel90 and LouisG - Tried the For GP18 to GP21 loop but that gives an Error : Pin 0/NULL is reserved on startup. I'm guessing GP18 is not reserved and being seen as a variable...
Phil99 - I was wondering how to set sequential GPnn with PIN numbers being non-sequential, pesky ground pins scattered regularly throughout :). What an elegant piece of code. May I nominate this as a code snippet for The Fruits of the Shed?
matherp - Maybe Phil99's elegant piece of code can make it into the manual as an example of dealing with programmatically assigning sequential GPnn.
Once again thank you everybody for your rapid response and guidance, it is much appreciated.
Maybe somebody can point me to an example of using the webmite to interrogate a Sunny Island and Sunny Boy using Modbus TCP? I live in hopes :)
Carl
Cheers Carl
Posted: 05:09pm 09 Aug 2023
That's interesting. Pins GP18-GP21 are free on the ordinary PicoMite but not on the PicoMite VGA, which uses them for the VGA display. In theory they should be free on the WebMite too, I think, but I've never used one.
Incidentally, I wouldn't consider allocating port pins in any other way than directly. Then I'd use sub to write to the port and a function to read it. That way it's very easy to change pin allocation for different setups.
pwrite 12
a=pread()
SUB PWRITE(value)
 port(GP0,4,GP7,4)=value
end sub
FUNCTION PREAD()
 pread=port(GP0,4,GP7,4)
end function
Posted: 12:01am 10 Aug 2023
@Carl,
Perhaps some bits and pieces like this could do it.
> LIST
Dim integer i, p, read.port, Up, Down
For i=4 To 11
 SetPin MM.Info(pinno "GP"+Str$(i)), dout
Next
Port(gp4,8) = &B00010000
For i = 11 To 4 Step -1
 p = MM.Info(pinno "GP"+Str$(i))
 Print Pin(p),
 read.port = (read.port << 1) + Pin(p)
Next
Print " Port Pins"
Print "read.port = "; Bin$(read.port, 8)
Up = read.port << 1
Port(gp4,8) = 0
Pause 30
Port(gp4,8) = Up
Print "Up = "; Bin$(Up, 8)
Down = read.port >> 1
Port(gp4,8) = 0
Pause 30
Port(gp4,8) = Down
Print "Down = "; Bin$(Down, 8)
> RUN
0       0       0       1       0       0       0       0       Port Pins
read.port = 00010000
Up = 00100000
Down = 00001000
carlschneider
Posted: 12:19am 10 Aug 2023
Thanks Phil99 I will have a look at the code.
Cheers Carl
