Local Time 21:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ATtiny BASIC - serial question...
Posted: 06:13am 07 Aug 2023
Hi all.
@ matherp: the software serial port you wrote for this port - can I access this using INPUT and PRINT?
...or is it STRICTLY a console port and nothing else?
Is there ANY way to use the console serial port you wrote inside a program?
Posted: 06:58am 07 Aug 2023
INPUT and PRINT should do all you want.
Posted: 07:20am 07 Aug 2023
As there is only one serial port, and that's the console, whatever you do is going to have to look and behave like a console.
Posted: 12:09am 08 Aug 2023
Thanks chums.
@ Mick - so noted.
My chips should be here along with the programmer this week, so I should be able to run some experiments.
