Local Time 21:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA: Sprite Collision Problems
Calli
Posted: 01:00pm 06 Aug 2023
I am on holiday and have the PicoMiteVGA with me, finally some time during rain to get some retro vibes.
Tried some old school game programming. However I am stuck with sprite collisions.
They does not work for me. I stripped down the example in the manual but either I dont understand or there is an error.
Attached the code and sprite of a stripped down version. No collisions...
I have some limited internet access here.
Cheers,
Carsten
D.zip
Posted: 11:06am 07 Aug 2023
Bump
There must be someone who can help. Alas, it's not me as I've never used sprites.
Martin H.
Posted: 12:39pm 07 Aug 2023
  Mixtel90 said  Bump
I never used the intern Collision detection...
but I seen one possible Bug in Callis Sub SprI:
st$="booom: "+str$(sprite(S))+" : "+str$(sprite(C,S))
but Variable S (in "sprite(C,S)") in not set in your code, it will allways be 0...
  Quote   SPRITE(C, [#]n )
Returns the number of currently active collisions for sprite n. If n=0 then
returns the number of sprites that have a currently active collision
following a SPRITE SCROLL command
so I think this should be
st$="booom: "+str$(sprite(S))+" : "+str$(sprite(C,sprite(S)))
Had no time to test it but how about the Subroutine, from the Manual Page 134-135?
SUB collision
LOCAL INTEGER i
' First use the SPRITE(S) function to see what caused the interrupt
IF SPRITE(S) <> 0 THEN 'collision of specific individual sprite
'SPRITE(S) returns the sprite that moved to cause the collision
PRINT "Collision on sprite ", SPRITE(S)
process_collision(SPRITE(S))
PRINT
ELSE '0 means collision of one or more sprites caused by background move
' SPRITE(C, 0) will tell us how many sprites had a collision
PRINT "Scroll caused a total of ", SPRITE(C,0)," sprites to have collisions"
FOR I = 1 TO SPRITE(C, 0)
' SPRITE(C, 0, i) will tell us the sprite number of the β€œI”th sprite
PRINT "Sprite ", SPRITE(C, 0, i)
process_collision(SPRITE(C, 0, i))
NEXT i
PRINT
ENDIF
END SUB
' get details of the specific collisions for a given sprite
SUB process_collision(S AS INTEGER)
LOCAL INTEGER i, j
' SPRITE(C, #n) returns the number of current collisions for sprite n
PRINT "Total of " SPRITE(C, S) " collisions"
FOR I = 1 TO SPRITE(C, S)
' SPRITE(C, S, i) will tell us the sprite number of the β€œI”th sprite
j = SPRITE(C, S, i)
IF j = &HF1 THEN
PRINT "collision with left of screen"
ELSE IF j = &HF2 THEN
PRINT "collision with top of screen"
ELSE IF j = &HF4 THEN
PRINT "collision with right of screen"
ELSE IF j = &HF8 THEN
PRINT "collision with bottom of screen"
ELSE
' SPRITE(C, #n, #m) returns details of the mth collision
PRINT "Collision with sprite ", SPRITE(C, S, i)
ENDIF
NEXT i
END SUB
Edited 2023-08-07 22:58 by Martin H.
'no comment
Calli
Posted: 01:12pm 07 Aug 2023
I mixed that up with the arguments like in framebuffer f etc...
Silly me.
Thanks πŸ‘
Carsten
