Forum Index : Microcontroller and PC projects : For Sprint Layout users
In spite of playing with Easy EDA now, I'm still also using Sprint Layout 6 and have accumulated some more Macros that you may find useful. Here ya go... Mick's SL6 Macros.zip I've included one for the 11-pin SD card connector that I've just received from ebay. https://www.ebay.co.uk/itm/382841375915 They look as good as anything else and are much cheaper than most. I'll probably be using these in future designs as they don't look any more difficult to solder than the others. Edited 2023-08-02 18:38 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10043 |
Thanks, Mick, I'll pop these in a folder and take a look later. ![]() Smoke makes things work. When the smoke gets out, it stops! |
