Local Time 21:51 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [Picomite] Optimizing for speed
fmafma
Posted: 08:02am 04 Jul 2023
Hi!
Do you have some tricks to optimize a program for speed?
For example, I found:
- use integers instead of floats;
- use SELECT CASE instead of IF / ELSEIF;
- use INC <var>, <increment> instead of <var> = <var> + <increment>;
What else?
Thanks,
Frédéric
Posted: 08:12am 04 Jul 2023
Keep interrupts as short as possible.
IDEALLY, set a flag, and then IMMEDIATELY exit the interrupt.
Have the main loop check the flags and action.
A VERY common mistake, is to put the code you WANT to execute, inside the interrupt, which is a very bad idea.  I know, cos I did it, and learned the hard way.
"Thou shalt not hang around in interrupts.".....
Posted: 08:28am 04 Jul 2023
The MATH commands process arrays very fast.
Use the minimum number of characters possible.
eg
Single letter variable names, Pin numbers not GPx numbers
No extra spaces in a line
Cram as many commands on a line as you can
Short FOR and DO loops on one line
> Dim integer n,a(100):For n=0 to 99:a(n)=Pin(1):next
Above all overclock, my Picos can all go to 378MHz.
Edit
the above for - next loop took less than 2mS at 378MHz.
> timer=0:For n=0 to 99:a(n)=Pin(1):next:?timer
1.72
Edited 2023-07-04 18:46 by phil99
andreas
Posted: 09:15am 04 Jul 2023
  fmafma said  Hi!
What else?
Thanks,
In a FOR i = 1 TO n
<do something>
NEXT
don't write NEXT i - write NEXT without i
Example:
with i runtime:  50356.933
without i runtime:  44866.376
> list
t = Timer
dummy = 0
For i = 1 To 1000000 '(one million)
 dummy = dummy+1
Next i
Print "with i runtime: ";Timer -t
t = Timer
dummy = 0
 dummy = dummy+1
Next
Print "without i runtime: ";Timer -t
-andreas
Edited 2023-07-04 19:22 by andreas
Posted: 09:20am 04 Jul 2023
explore CONSTs and radices (&h, &b etc). I covered this in my tips page (beware this is aimed at MicroMite so not everything will be applicable)
http://www.fruitoftheshed.com/MMBasic.Some-Hints-Tips-for-writing-efficient-code.ashx
Martin H.
Posted: 10:20am 04 Jul 2023
What else?
Thanks,
instead of
if Deg >359 then Deg=Deg-360
if Deg<0 then Deg=Deg+360
use
inc deg,-360*(deg>359)+360*(deg<0)
'no comment
Posted: 10:26am 04 Jul 2023
deg=(deg + 360) mod 360
Edited 2023-07-04 20:28 by matherp
Posted: 11:05am 04 Jul 2023
  CaptainBoing said  my tips page ... http://www.fruitoftheshed.com/MMBasic.Some-Hints-Tips-for-writing-efficient-code.ashx
Cap'n--I can't access fruitoftheshed any longer--I just get a blank page. This occurs with Chrome, Iridium, Edge, and Brave browsers, and also on my phone.
This appears for me to be related to http vs https--some time ago chrome stopped working but iridium still did. Any ideas? Anyone else having the same problem?
Edited 2023-07-04 21:05 by lizby
Martin H.
Posted: 11:34am 04 Jul 2023
  matherp said  deg=(deg + 360) mod 360
what I wanted to show was that logical comparisons can be included in the formula
Edited 2023-07-04 21:36 by Martin H.
'no comment
Posted: 12:02pm 04 Jul 2023
I can see it OK. Sorry, I don't know what else you can try other than clearing browser cache / reboot / wonder if ISP has (bizarrely) blocked the site.
Posted: 12:36pm 04 Jul 2023
DEG() is a function. Name a variable same is not recommended.
Posted: 12:40pm 04 Jul 2023
FoTS seems to be working here. I blame the US. ;)
Martin H.
Posted: 01:02pm 04 Jul 2023
of course you're right, it was only meant as an example
'no comment
stanleyella
Posted: 01:48pm 04 Jul 2023
Use if a=1 then if b=2 then
instead of
if a=1 and b=2 then
if the 1st condition fails it skips the 2nd test
use var=not var   to toggle a var
2 code examples, they do the same but one uses 3 arrays to do the same.
cdy(cm)=(py>cy(cm))-(py<cy(cm))  and cdx(cm)=(px>cx(cm))-(px<cx(cm)) speed it,
or do they?
it's computer y direction=(player y>computer y)-(player y<computer y)
and computer x direction=(player x>computer x)-(player x<computer x)
is this safe logic?
'computer move
   for cm=1 to 3
     if cpa(cm)=1 then
       if cdx(cm)<>0 then
         if pixel (cx(cm)+cdx(cm),cy(cm)) >0 then
           cdx(cm)=0:cdy(cm)=(py>computer y direction=(player y>computer y)-(player y<computer y)cy(cm))-(py<cy(cm))
         end if
       else
         if pixel (cx(cm),cy(cm)+cdy(cm)) >0 then
           cdy(cm)=0:cdx(cm)=(px>cx(cm))-(px<cx(cm))
         end if
       end if
       cx(cm)=cx(cm)+cdx(cm):cy(cm)=cy(cm)+cdy(cm)
    next
'computer move
if cdx%=-1 then
  if pixel (cx%-1,cy%) >0 then
    cdx%=0
    if py%>cy% then
      cdy%=1
    else
      cdy%=-1
    end if
  end if
else if cdx%=1 then
  if pixel (cx%+1,cy%) >0 then
    cdx%=0
    if py%>cy% then
      cdy%=1
    else
      cdy%=-1
    end if
  end if
else if cdy%=-1 then
  if pixel (cx%,cy%-1) >0 then
    cdy%=0
    if px%>cx% then
      cdx%=1
    else
      cdx%=-1
    end if
  end if
else if cdy%=1 then
  if pixel (cx%,cy%+1) >0 then
    cdy%=0
    if px%>cx% then
      cdx%=1
    else
      cdx%=-1
    end if
  end if
end if
cx%=cx%+cdx%:cy%=cy%+cdy%
Edited 2023-07-05 01:26 by stanleyella
Martin H.
Posted: 03:40pm 04 Jul 2023
yes
> option cpuspeed 378000
> RUN
IF  201.248
MOD  177.022
Calc  223.552
> list
de%=0:CLS
t%=Timer
For f=0 To 10000:Inc de%:If de%>359 Then de%=0
Next
Print "IF ";Timer-t%:t%=Timer
For f=0 To 10000:Inc de%:de%=(de% + 360) Mod 360:Next
Print "MOD ";Timer-t%:t%=Timer
For f=0 To 10000:Inc de%:Inc de%,-360*(de%>359):Next
Print "Calc ";Timer-t%:t%=Timer
the MOD Version is the fastest and to my suprise, the "IF" Version is faster than the Calculated version
'no comment
Bleep
Posted: 04:37pm 04 Jul 2023
Hi Martin,
You are only doing half of the If comparison, what about the
If Deg<0 then Deg=Deg+360
Edited 2023-07-05 02:39 by Bleep
stanleyella
Posted: 04:50pm 04 Jul 2023
  phil99 said  The MATH commands process arrays very fast.
 math scale samples!(),80,samples!()
 math add samples!(),0,old_samples!() 'copies a() to b()
not obvious this just copies with 0 but a good tip
Posted: 04:55pm 04 Jul 2023
  Quote  not obvious this just copies with 0 but a good tip
Check the manual entries for MATH SET, MATH SCALE and MATH ADD.
Posted: 04:58pm 04 Jul 2023
check your DMs
hhtg1968
Posted: 05:27pm 04 Jul 2023
  andreas said
  fmafma said  Hi!
What else?
Thanks,
In a FOR i = 1 TO n
<do something>
NEXT
Example:
> list
t = Timer
dummy = 0
 dummy = dummy+1
Next i
t = Timer
dummy = 0
 dummy = dummy+1
Next
-andreas
very cool tip. first i do not believe it.
