Local Time 01:30 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ili9341 vs  ST7789
stanleyella
Posted: 04:13pm 27 Jun 2023
I'm thinking of buying a  ST7789 display. Is it faster than ili9341? I heard it has a wider viewing angle. Any other advantages? Cheers, stan.
Posted: 04:28pm 27 Jun 2023
I don't think there's much difference in speed between any of the SPI displays, other than that gained by not needing to update as many pixels on small ones.
If you want a fast LCD TFT then the one to get is the SSD1363 parallel display. They do tend to be a bit expensive now though, and they use a lot of GP pins.
If you do decide to get a ST7789 then make sure you get one with a CS pin as modifying the ones without is very fiddly. The control chip number has nothing to do with the viewing angle.
stanleyella
Posted: 04:48pm 27 Jun 2023
  Mixtel90 said  I don't think there's much difference in speed between any of the SPI displays, other than that gained by not needing to update as many pixels on small ones.
Finding st7789 with cs and miso/sdi seems the 320x240 with sd card and touch.
very fiddly and solder ribbon and cut tracks from google.
Posted: 05:06pm 27 Jun 2023
  Mixtel90 said  If you want a fast LCD TFT then the one to get is the SSD1363 parallel display.
The SSD1963?
stanleyella
Posted: 05:35pm 27 Jun 2023
Sort of on thread for buying displays.. would this work, silly price, con?
https://www.ebay.co.uk/itm/285173803237?
Posted: 06:35pm 27 Jun 2023
Sorry, yes. SSD1963. Brain-keyboard interface is faulty.
}Out of cheese error
Posted: 06:42pm 27 Jun 2023
No idea if that will work, Stan. Not particularly cheap at 19 UKP when you don't know.
stanleyella
Posted: 02:10pm 28 Jun 2023
  Mixtel90 said  No idea if that will work, Stan. Not particularly cheap at 19 UKP when you don't know.
£2.99 my bad. sorry, thought tgtbt. I'll use the ili displays I have for now as they're fine.
Pity there no cheap small vga lcd displays and keyboards. I mean cheap.
my vga picomite setup cost nothing just space.
cheers stan.
