Local Time 01:16 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wait time between characters when sending serially
Frank N. Furter
Posted: 10:41am 26 Jun 2023
is there a way to force a wait time between characters when sending via serial port? Like it is possible with TeraTerm (Transmit delay msec/char)?
Thanks!
Frank
Posted: 11:45am 26 Jun 2023
The only way I can think of to do that would be to send character by character rather than send a string. There's no setting that I know of to do it.
If you need a low baud rate (less than 1200) it might be better to bitbang the output rather than use the COM system. It may tie up your program during transmit though. I suppose you could use SETTICK to send characters at set intervals that way.
Frank N. Furter
Posted: 06:33am 27 Jun 2023
Hi Mick,
that's a good idea. I am afraid that there will be no other possibility - what a pity!
I want to communicate with my HX-20 and he needs a breather between characters...
Frank
Posted: 06:51am 27 Jun 2023
  Frank N. Furter said  Hi Mick,
Frank
Try setting the serial to two stop bits.
That often is enough.
Posted: 07:38am 27 Jun 2023
If that's not slow enough I suppose you send 1 char, wait for it to go, pause & repeat.
You've done worse, I expect!
aFox
Posted: 06:56pm 27 Jun 2023
Hi
I found this
datenaustausch-mit-dem-epson-hx-20-unter-windows
and this
datenuebertragung-vom-pc-zum-epson-hx-20
Sorry only in German, but Google Translate is your friend.
Gregor
Frank N. Furter
Posted: 06:40am 28 Jun 2023
  Quote  Hi
I found this
and this
Yes, and on this basis I would like to build a device to communicate between HX-20 and PicoMite...
Frank
NPHighview
Posted: 10:38pm 28 Jun 2023
Wow - a flash from the past! I implemented an electric meter reading application on the HX-20 in Basic in about 1984, and then found a company that wrote callable Hitachi 6301 assembly language code for it to dramatically speed up microcassette tape I/O (almost identical to CSUBs in MMBasic). Sold as a commercial meter reader to electric utilities.
Epson HX-20 Wikipedia
I really liked the Z-80-based successor to the HX-20 (the Epson PX-8), for which I configured the CP/M program "VEDIT" (a superb text editor from Greenview Data in Ann Arbor, Michigan). Solid as a rock...
Epxon PX-8 Wikipedia
Edited 2023-06-29 08:38 by NPHighview
Posted: 06:15am 29 Jun 2023
Use the BITBANG SERIALTX routines.
When I ported some PICAXE code to MMBASIC, the buffered COM ports played havoc with the PICAXE based receiver unit.  The way to fix it was to add 2ms of delay between the data-slicer sync bytes and the payload.
SUB TRANSMIT (DTA$) 'MUST send the message this way, to make it work with the PICAXE data filter.
 LOCAL T$
 T$="UUUUUUUUUUUUUUU" 'Preamble bytes(10101010) to sync the data-slicer in the receiver
 PIN(EN)=1 'Enable NTX2 transmitter
 PAUSE 15 'Allow NTX transmitter to power-up
 FOR X=1 TO LEN(T$)
   BITBANG SERIALTX TXD,2400,MID$(T$,X,1) 'Send message one byte at a time.  Introduces small delay between bytes for the PICAXE decoder.
   PAUSE 1 'Needed to help the PICAXE 08M2 decoder - DO NOT REMOVE!!!
 NEXT X
 PAUSE 2 'Separation delay between sync bytes and actual packet - DO NOT REMOVE!!!
 FOR X=1 TO LEN(DTA$)
   BITBANG SERIALTX TXD,2400,MID$(DTA$,X,1) 'Send message one byte at a time.  Introduces small delay between bytes for the PICAXE decoder.
 NEXT X
 PAUSE 25
 PIN(EN)=0 'Disable NTX2 module
END SUB
The beauty of SERIALTX and SERIALRX is that they are blocking, which CAN be a very much desired thing, such as in my case, where using the buffered COM port squirts the packet out with no delays, and aligns all the data bytes right beside each other and the PICAXE receiver TOTALLY ignores it.
The routine above may not be that elegant, but it works, and it works 100% of the time, and that is the most important bit.
Frank N. Furter
Posted: 06:25am 29 Jun 2023
Hi Grogster,
thank you very much, this looks very good!!!
Frank
