Local Time 01:30 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : graphics off screen ok?
stanleyella
Posted: 09:53pm 24 Jun 2023
Hi, using lcd graphics can go off screen and no error. please see example. This could be useful but is it safe to use? Where does the box go off screen?
'320x480 lcd
dim bx,by,bxl,byl
bx=50:by=50
cls
box bx,by,24,24,1,rgb(white)
do
bxl=bx
bx=bx-1
if bx=-24 then bx=479 'can be if bx=-240? change to bx=319 for 320x240
box bxl,by,24,24,1,rgb(black)
pause 10
loop
the box doesn't wrap around, it collapses one side then expands the other side if you increase the pause to 100 you see it.
Edited 2023-06-25 08:01 by stanleyella
Posted: 10:33pm 24 Jun 2023
  Quote  This could be useful but is it safe to use? Where does the box go off screen?
In the beginning going off screen could cause problems, but I think Peter changed it so that plotting pixels beyond the borders can't happen. As there is no buffer beyond the border they just vanish without error, so as far as I can tell it is safe to do.
As noted in the other thread graphic objects are not sprites, they are not stored anywhere. They are calculated and drawn from scratch each time you invoke them.
