Local Time 22:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : why "Error : Pin not set for I2C"?
Posted: 06:04pm 23 Jun 2023
PicoMite MMBasic Version 5.07.08b6
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
> option list
OPTION SYSTEM I2C GP14,GP15
OPTION COLOURCODE ON
OPTION DISPLAY 43, 120
OPTION LCDPANEL SSD1306I2C, LANDSCAPE, 2
OPTION RTC AUTO ENABLE
> text 0,0,"This is line 1"
> ?date$,time$
01-01-2000      00:00:37
> rtc settime "23/06/23 14:57"
> ?date$,time$
23-06-2023      14:57:03
> run
    0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
00:
[12] I2C write addr, 0, 1, &H00  ' write zero to that adress
> list
' i2cdetect like program
' Prep table
Print "     0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F"
' loop col/row
For y=0 To 7
Print Hex$(y,2);": ";
For x=0 To 15
 addr = y*16+x               ' calc address
 If MM.I2C=0 Then            ' check for errors
   Print Hex$(addr,2);" ";   ' found one!
Else
  Print "-- ";               ' nothing here..
EndIf
Next x
Print
Next y
From the command line, the LCD is written to successfully, and the RTC is set with "RTC SETTIME", but the program to detect I2C devices fails with "Error : Pin not set for I2C" even though the system I2C is set.
stanleyella
Posted: 06:32pm 23 Jun 2023
' Set Pins!
SetPin gp14, gp15, I2C
' Open first I2C
I2C open 100, 200
Edited 2023-06-24 04:41 by stanleyella
Posted: 08:00pm 23 Jun 2023
Per the manual: "The I2C based display controllers use the SYSTEM I2C pins as per the pinout for the specific device. Other I2C devices can share the bus subject to their addresses being unique.
If an I2C display is configured it will not be necessary to "open" the I2C port for an additional device (I2C OPEN)".
Am I misunderstanding what the manual is saying?
Posted: 08:15pm 23 Jun 2023
Pin gp14 and gp15 are I2C2, not I2C
Posted: 09:50pm 23 Jun 2023
  Volhout said  Pin gp14 and gp15 are I2C2, not I2C
That was it. Working now on I2C2. Thanks.
