Local Time 22:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico W Bluetooth news
Plasmamac
Posted: 10:40am 14 Jun 2023
Read here :
Pico news
Plasma
aFox
Posted: 02:43pm 14 Jun 2023
  Plasmamac said  Read here :
Pico news
Cold coffee.
Plasmamac
Posted: 03:17pm 14 Jun 2023
Haha news from today
Plasma
Posted: 03:39pm 14 Jun 2023
IIRC the earlier version was discussed some time ago.
Posted: 05:55pm 14 Jun 2023
I think it was originally announced in February, but I don't think there was any python support at that time, so maybe that part is new. :)
Quazee137
Posted: 06:22pm 15 Jun 2023
Not sure about asking this but could the pico W plugged into one of Mixtel's
VGA board make use of bluetooth keyboards.
Quazee137
Posted: 09:23pm 15 Jun 2023
I don't think the Webmite supports Bluetooth does it? The Pico W probably could, but you would need to sort out drivers etc. - and probably run Circuit Python on it.
Quazee137
Posted: 04:47pm 17 Jun 2023
Ya missed what I was getting at. Can there be a PicoVGA-BT no web just the
 bluetooth for keyboard and sound. Far easier to get keyboard and speakers for.
 Also a PicomiteBT with the bluetooth so LCD and keyboard would make for a
 system that could be used to do coding at the park or coffee shop.
 A nice portable unit with a USB power bank.
 was just asking is all.
 Quazee137
Edited 2023-06-18 02:48 by Quazee137
Posted: 07:21pm 17 Jun 2023
As the built-in bluetooth on the Pico W isn't supported by MMBasic then it would have to be done with modules. A bluetooth to TTL adapter would get a keyboard input. Dunno about sound - there will be audio to bluetooth modules for it, I suppose.
What you probably need for programming is a bluetooth link from a tablet into a COM port of the PicoMite, acting as the console. MMB4W on a laptop is a lot easier. :)
Posted: 12:24pm 20 Jun 2023
  Quazee137 said  Ya missed what I was getting at. Can there be a PicoVGA-BT no web just the
In theory, yes. In practice, no, unless someone writes the code.
aFox
Posted: 01:54pm 20 Jun 2023
I tried. But the simplest examples failed under the Windows IDE, which Peter also uses.
Apparently it can only be successfully compiled on Linux.
I then switched to the Arduino IDE.
I am still convinced of the good performance of Bluetooth with the PICO W.
So I built a Bluetooth Adapter
Bluetooth Adapter by Pico W
Maybe there is an option of a flash memory on its second core used by a second serial connection.
Gregor
Edited 2023-06-20 23:54 by aFox
