Local Time 22:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reset Single OPTIONs?
Calli
Posted: 03:07pm 13 Jun 2023
Maybe I miss something.
I need for a test to switch between PWM and SPI audio. Is there a command to clear an OPTION, I mean like OPTION AUDIO OFF?
Other that OPTION RESET
Best,
Carsten
Posted: 03:59pm 13 Jun 2023
OPTION AUDIO DISABLE
IanRogers
Posted: 09:21pm 13 Jun 2023
I was playing with this.
I think ( and I may be wrong, most of the time this is true )
You can just type the  OPTION AUDIO xxxxx and it seems to overwrite the exsisting.
My 2 penneth.
I'd give my left arm to be ambidextrous
Posted: 09:53pm 13 Jun 2023
You might be right, Ian. I've not played with a PWM/SPI setup yet.
Calli
Posted: 07:51am 15 Jun 2023
  Mixtel90 said  OPTION AUDIO DISABLE
To my defense, it is not noted in the documentation near the AUDIO option :)
Thanks,
Carsten
