Local Time 22:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : On the Picomite, with EXECUTE, why am I getting Error: Unknown Command
Posted: 05:56pm 10 Jun 2023
> option escape
> ? "Pin(34)=";pin(34)
Pin(34)= 1
> t$="? \qPin(34)=\q;pin(34);"
> execute t$
Pin(34)= 1
Error : Unknown command
> ?t$
? "Pin(34)=";pin(34);
If from the command line I enter: ? "Pin(34)=";pin(34)
I get the expected result printed: "Pin(34)= 1" (because I have made pin 34 an output have set PIN(34)=1)
But when I set a string to that command: t$="? \qPin(34)=\q;pin(34);"
then EXECUTE t$
I get the expected output printed, but followed by "Error : Unknown command"
Posted: 06:11pm 10 Jun 2023
Execute isn't intended to be run from the command prompt. I'll block it in a future release
Posted: 07:05pm 10 Jun 2023
Ok. Was just using it to test, anyway. In a program, it works:
> list
Option escape
SetPin 34,dout
Pin(34)=1
Execute t$
> run
Pin(34)= 1
Edited 2023-06-11 05:07 by lizby
