Local Time 22:29 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SDcard missing
VK2AHB
Posted: 01:38am 09 Jun 2023
Using these options, all has been fine.
> option list
OPTION SYSTEM I2C GP2,GP3
OPTION LCDPANEL ILI9488, PORTRAIT,GP15,GP14,GP13
OPTION TOUCH GP12,GP11
OPTION SDCARD GP22
OPTION RTC AUTO ENABLE
Now suddenly, SDCARD is not found
I have reset all and re-entered.
Paul VK2AHB
ice2642
Posted: 01:48am 09 Jun 2023
Just some ideas,
The SD was formatted in fat16 or fat32 ? Try an other SD-card to test if the problem is not in SD-card.
Do you check if the wire is well connected?
Best Regards,
MMBasic 5.0707 on PicoMite VGA
Posted: 02:18am 09 Jun 2023
Do you have the ILI9488 LCD_SDO connected directly to MISO - GP16?
If so that will block access to the SD card. Connect a Schottky diode with anode to LCD_SDO and cathode to MISO. Add a 10k resistor from LCD_CS to MISO.
The  ILI9488 chip has a fault that prevents sharing MISO. For a quick test disconnect LCD_SDO and see if the SD card works.
VK2AHB
Posted: 06:02am 12 Jun 2023
"Do you have the ILI9488 LCD_SDO connected directly to MISO - GP16?"
option SYSTEM SPI GP18, GP19, GP16
OPTION LCDPANEL ili9488, p, GP15, GP14, GP13.
Thank you Phil, I'll have a look in the junk box for a diode.
There is another thread about this display with the same probs that I have. ILI9341 only shows 240x240. It is referenced in my other thread above this one.
I can use the SDCard by OPTION RESET , setting the SDCard option as per the board, then loading the file I want.
The link referred to above mentions feeding with 3.3V instead of 5V, I will have to investigate.
Paul VK2AHB
hhtg1968
Posted: 06:20am 12 Jun 2023
Did you ever had access to an/ the sd card?
I got this error message too. i bought an sd-card adapter for 5v (arduino). the pico uses 3.3v.
i use a bridge between 5v and 3.3v (thanks to this forum!!!!) and now it is running!
