Local Time 22:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DEL key picomite
hhtg1968
Posted: 06:28am 28 May 2023
Hello,
i am using picomites and webmites with fun.
but when i am editing with the integrated editor i cannot use the normal DEL key. if i use it, it cleares the character at the cursor, but it does not move left. so it functions like the CLEAR key, not like DEL.
i am using a mac and the screen command from terminal app (like description in the official manual).
what is wrong?
Posted: 06:37am 28 May 2023
There should be a setting in Screen where you can change the function of the delete key.
IanRogers
Posted: 07:31am 28 May 2023
I was sure the "backspace" key did that job.. You can set it in the terminal program you are using.
I'd give my left arm to be ambidextrous
Posted: 02:56pm 28 May 2023
Picomite used <control>-H for delete.
Terminal programs typically have a setting for this.
This screenshot is from Putty. The default value (control-127) is wrong for the build in editor in MMBasic.
Edited 2023-05-29 00:58 by Volhout
hhtg1968
Posted: 04:48pm 28 May 2023
in the editor of picomite ctrl-h functions like a correct DEL/ backspace. but not the DEL key on the keyboard. in the terminal app from macos both variants (DEL or ctrl-h) can be used. so it must be in the SCREEN command. but the man file of SCREEN is too long...
i will google further on to find a solution...
IanRogers
Posted: 06:32pm 28 May 2023
You do know Putty is available on the MAC..
Then you can use all the advise from people here.
"sudo port install putty"
Posted: 06:38pm 28 May 2023
Or google....
First hit =
backspace
hhtg1968
Posted: 08:24pm 28 May 2023
i am not so sure...
