Local Time 22:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OLED 1.3" Blue.. RGB Colour
asknik2022
Posted: 07:55am 27 May 2023
Does anybody know the actual RGB (?,?,?) colour numbers are so that I cabn use the same colour on an ILI9341 Display
Posted: 08:23am 27 May 2023
You could find out by trial and error.
Blues are from 0 to 248 in steps of 8. Red and blue are 5 bit and green is 6 bit.
eg
for b% = 0 to 248 step 8 : cls b% : print RGB(0,0,b%) : pause 500 : next
When the colour is right note the last value of b%
If none of those are quite right add some red or green and try again.
Posted: 08:48am 27 May 2023
MMBasic will try to map to the closest available colour, I think.
IanRogers
Posted: 11:53am 27 May 2023
  asknik2022 said  Does anybody know the actual RGB (?,?,?) colour numbers are so that I cabn use the same colour on an ILI9341 Display
Again! I just use paint in windows.. The colour picker is pretty good.
I draw or copy a picture and use the pixel picker then look at the RGB values in the colour picker. ( just double click "Edit Colours")
I'd give my left arm to be ambidextrous
