Forum Index : Microcontroller and PC projects : 1 pin button pad
| stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807 |
Hi. the quid button pads arrived and seem to work. Using at 3.3V though they're arduino so for 5V. results for up,down,left,right,right button. SETPIN 31, AIN do PRINT PIN(31) pause 1000 loop ![]() |
this will be easier to case SETPIN 31, AIN do bp=int(PIN(31)*1000) PRINT bp 'PIN(31) pause 1000 loop |
It works well. My tron game is much more playable compared to touch area buttons.. and poking lcd screens is not good for them.Good button pad for the price of a mars bar and uses just 1 pin. OPTION EXPLICIT OPTION DEFAULT NONE OPTION DEFAULT INTEGER OPTION BASE 1 'arrays start at 1 option autorun on dim px,py,pdx,pdy dim cx(3),cy(3),cdx(3),cdy(3),cpa(3) dim ts,tr,csc=0,psc=0,cm dim bp SETPIN 31, AIN cls do 'init players start positions px=260:py=rnd*120+60:pdx=-1:pdy=0 cx(1)=rnd*100+80:cy(1)=50:cdx(1)=0:cdy(1)=1:cpa(1)=1 cx(2)=rnd*100+80:cy(2)=190:cdx(2)=0:cdy(2)=-1:cpa(2)=1 cx(3)=rnd*50+50:cy(3)=rnd*80+80:cdx(3)=1:cdy(3)=0:cpa(3)=1 'draw play area & 4 random triangles on border box 0,0,319,239,1,rgb(white),rgb(black) ts=rnd*160+40 triangle 0,ts,12,ts+8,0,ts+16,rgb(White) ts=rnd*160+40 triangle 319,ts,307,ts+8,319,ts+16,rgb(White) ts=rnd*240+40 triangle ts,0,ts+8,10,ts+16,0,rgb(White) ts=rnd*240+40 triangle ts,239,ts+8,228,ts+16,239,rgb(White) line 0,239,80,239,1,rgb(blue)'left button line 140,239,220,239,1,rgb(blue)'right button line 319,40,319,120,1,rgb(blue)'up button line 319,179,319,239,1,rgb(blue))'down button 'main do 'check user button pressed bp=int(PIN(31)*1000) if bp<3000 then 'if less than 3.3V then a button pressed button end if px=px+pdx:py=py+pdy 'has player crashed if pixel (px,py) >0 then 'player crashed box 0,0,319,239,1,rgb(white),rgb(black) text 60,100,"You Lost",l,5:pause 5000:exit do end if pixel px,py,rgb(magenta) 'computer move for cm=1 to 3 if cpa(cm)=1 then if cdx(cm)<>0 then if pixel (cx(cm)+cdx(cm),cy(cm)) >0 then cdx(cm)=0:cdy(cm)=(py>cy(cm))-(py<cy(cm)) end if else if pixel (cx(cm),cy(cm)+cdy(cm)) >0 then cdy(cm)=0:cdx(cm)=(px>cx(cm))-(px<cx(cm)) end if end if cx(cm)=cx(cm)+cdx(cm):cy(cm)=cy(cm)+cdy(cm) 'has computer player crashed if pixel (cx(cm),cy(cm)) >0 then cpa(cm)=0'computer crashed if cpa(1)+cpa(2)+cpa(3)=0 then 'all crashed box 0,0,319,239,1,rgb(white),rgb(black) text 70,100,"You Won",l,5:pause 5000:exit do end if end if pixel cx(cm),cy(cm),rgb(yellow) end if next cm pause 50 'game speed loop loop sub button 'which button pressed? if bp<20 then if pdx=0 then pdy=0:pdx=-1:end sub'left pressed? if bp<1800 then if bp>1500 then if pdx=0 then pdy=0:pdx=1:end sub'right pressed? if bp<700 then if bp>300 then if pdy=0 then pdx=0:pdy=-1:end sub'up pressed? if bp<1200 then if bp>900 then if pdy=0 then pdx=0:pdy=1'down pressed? end sub |
1 hand and a camera in the other https://www.youtube.com/watch?v=ChLwrszmFig |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9329 |
SELECT/CASE might be a better way to test the buttons. do bp=pin(31) select case bp case <.02 do stuff here case 0.6 to 0.72 do stuff here case 1.1 to 1.3 do stuff here case 1.78 to 1.82 do stuff here end select loop (values shown are only examples) It has a couple of advantages. You are window testing so you can easily test for buttons while still allowing for resistance tolerances. Good for diagonals. It's fast. You can put the most likely buttons early in the select statement then any later ones won't be tested. No *1000 needed - FP is as fast as integers. You can make it very structured if you want too. with each case setting the direction then calling a common movement sub. Just an idea - it may be worth a try for comparison. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thanks Mick. I converted the original touch screen using case to a sub as I was not sure how to use case in this instance so thanks for the info. Will try. 'define touch areas gui area 1,0,199,80,40 ':line 0,239,80,239,rgb(blue)'left button gui area 2,140,199,80,40 ':line 140,239,220,239,rgb(blue)'right button gui area 3,279,40,40,80 ':line 319,40,319,120,rgb(blue)'up button gui area 4,279,159,40,80 ':line 319,179,319,239,rgb(blue)'down button 'check user button pressed tr=TOUCH(REF) if tr>0 then select case tr case 1 'left pressed if pdx=0 then pdy=0:pdx=-1 case 2 'right pressed if pdx=0 then pdy=0:pdx=1 case 3 'up pressed if pdy=0 then pdx=0:pdy=-1 case 4 'down pressed if pdy=0 then pdx=0:pdy=1 end select end if px=px+pdx:py=py+pdy Touch buttons work but not too good with finger presses. The button board is much better and the buttons click when pressed but pressing 2 buttons at once needs another look at. Handy board for the price. Cheers, stan |
Case worked using float var 'check user button pressed bp!=pin(31) if bp!<3.1 then 'a button has been pressed select case bp! case <.02 if pdx=0 then pdy=0:pdx=-1 'left pressed case 1.5 to 1.8 if pdx=0 then pdy=0:pdx=1 'right pressed case 0.3 to 0.6 if pdy=0 then pdx=0:pdy=-1 'up pressed case 0.9 to 1.1 if pdy=0 then pdx=0:pdy=1 'down pressed end select endif px=px+pdx:py=py+pdy I guess I could skip case 0.9 to 1.1 as if the other 3 buttons were not pressed then it must be the last one. happy trails, stan |
The variables default to float so you don't really need the ! either unless you've used OPTION DEFAULT INTEGER. :) You don't really need the test for <3.1 either. Not in this case as there aren't that many comparison tests so it's not going to slow things down much. YMMV of course. You can use CASE ELSE as the last case and use it to zero pdx and pdy. That will make it do nothing if no buttons are pressed. Mick Zilog Inside! nascom.info for Nascom & Gemini |
if bp!<3.1 then 'a button has been pressed is there to see why bother testing no keys pressed Mick, you have shown a way of case that wasn't obvious to me from the manual.ta That float is fast I got to get used to...not used to it in microcontroller basic the post was about the button pad and how cheap and it works easy with 1 a to d pin. I'm impressed it's so simple yet works. switches and pull ups and de bounce and wires and lots of gpio pins l8r. for 5 buttons this is handy.. in the spirit,hobbyist is float as fast as integer? I can't be to do loops and timer to try, someone else must have done this. Edited 2023-05-28 06:14 by stanleyella |
Floats are pretty fast, but integer is still faster, generally. Try using a float as a for-next variable and compare it with an integer. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
