Local Time 22:54 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pico W - mmbasic UDP
Plasmamac
Posted: 05:34pm 22 May 2023
HI Matherp,
will UDP support ever come for MMBasic?
thx
Plasma
aFox
Posted: 02:20pm 23 May 2023
Hi
Why not?
TFTP is implemented and based on UDP as transport layer.
The security problem arises for both TFTP and UDP.
Both should only be activated via an OPTION.
And only if it is ensured that there is no access to the Internet.
Gregor
Posted: 07:07pm 23 May 2023
What is the security risk of UDP?
aFox
Posted: 07:27pm 23 May 2023
  lizby said  What is the security risk of UDP?
1.
2.
3.
Edited 2023-05-24 05:28 by aFox
Posted: 09:04pm 23 May 2023
2 & 3 are the same URL
With a Pico W:
I can't say #1 would bother me.
2 & 3 seem irrelevant - wrong URL?
Edited 2023-05-24 07:08 by JohnS
NPHighview
Posted: 11:03pm 23 May 2023
The main security risk that I'm aware of is that most people setting up a firewall aren't thinking in terms of UDP.
In a previous incarnation, I was at a cocktail party where the host was discussing the process controllers at a large industrial concern for which we both worked. I asked him about security of those controllers (this was a few months after 9/11 and everyone was still on edge). He was confident they were secure. I asked if he remembered any of their addresses; he said he did. We downloaded a UDP browser to his home computer, typed in the address, and up came the user interface for one of the process controllers.
He said something I won't repeat here, excused himself, quickly drove to work while on the phone to the IT lead, and reappeared an hour later, smiling, but wiping the sweat from his brow. "Firewall fixed," he said.
Posted: 01:52am 24 May 2023
Ok, so it's a security risk if you expose your control interface through UDP. How about otherwise, e.g., you just have a program listening for a coherent message?
Posted: 06:41am 24 May 2023
  NPHighview said  We downloaded a UDP browser to his home computer, typed in the address, and up came the user interface for one of the process controllers.
Clearly a problem in that case, but a Pico W isn't likely to have such an interface and even if it did it's up to its user(s) to be aware of possible problems - just as they would with a TCP interface or UART one or (etc).
I'm not seeing a specific issue of any major worry about UDP.
Obviously a hole in the RPi Pico UDP code might be an issue, but so would a hole anywhere else (TCP, MMBASIC, user code).
Posted: 06:45am 24 May 2023
  lizby said  Ok, so it's a security risk if you expose your control interface through UDP. How about otherwise, e.g., you just have a program listening for a coherent message?
I suppose it's a risk if you foul up your code (not specific to UDP, though).
Also, if there's a hole in the RPi Pico UDP code. But that applies to all the other things such as their TCP code, MMBASIC etc.
Doesn't look worrying about unless you're in a rather important security-conscious environment in which case I doubt MMBASIC would be allowed at all (no offence to MMBASIC but the kinds of rules imposed in such environments are tough).  They'd likely want security-audited Pico code, too, and a bunch of other stuff. Let's not go there!
Posted: 07:20am 24 May 2023
Of course, it's up to the individual to decide on whether or not to connect a PicoMite to the internet in any form, but it would be *very unwise* to have it on the same network as anything you want to protect. At the very least put it on a different set of internal IP addresses from the rest of your network. Don't trust DMZ in the router, there are too many ways round/through that - if the router is even implementing it properly.
Everything you can think of to protect your network has probably been hacked at some point. It's a chilling thought.
All that's needed is one weak point (perhaps the device doesn't check for a buffer overflow) and a hacker can worm their way onto the main network.
Posted: 12:04pm 24 May 2023
Thanks, John. I have no intention of exposing UDP to the internet from any device--I just wondered if there was anything inherently insecure about doing that (assuming as always that you are doing your best to make sure that your method of listening for UDP messages doesn't allow malicious access).
My main interest in UDP on the PicoMite would be as a sender (though there is MQTT for that). I have some devices which now send UDP messages on my internal network to an accumulator which records them.
