Local Time 22:54 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Free Atmel processors
Posted: 12:49pm 22 May 2023
I have three Atmel 89S52 24MHz processors in a tube (apparently NOS) if anyone wants them.
Data sheet available Here
These are not exactly brilliant by today's standards but may be of historical interest to someone.
(from data sheet)
• Compatible with MCS-51® Products
• 8K Bytes of In-System Programmable (ISP) Flash Memory
– Endurance: 1000 Write/Erase Cycles
• 4.0V to 5.5V Operating Range
• Fully Static Operation: 0 Hz to 33 MHz
• Three-level Program Memory Lock
• 256 x 8-bit Internal RAM
• 32 Programmable I/O Lines
• Three 16-bit Timer/Counters
• Eight Interrupt Sources
• Full Duplex UART Serial Channel
• Low-power Idle and Power-down Modes
• Interrupt Recovery from Power-down Mode
• Watchdog Timer
• Dual Data Pointer
• Power-off Flag
If you are interested PM me - otherwise they go in the bin at weekend.  :)
No charge for the processors - and I'll throw the tube and antistatic bag in for free too! I don't know what the postage will be, but I'll cover it within the UK.
IanRogers
Posted: 01:37pm 22 May 2023
Shame.. I stopped using 8051's way back. As they are 'S' types they can be programmed a lot easier..
Where in Blighty are you?
I'd give my left arm to be ambidextrous
Posted: 02:12pm 22 May 2023
I'm close to Preston, Lancashire.
They appear to be able to be programmed serially as SPI slaves. I've no idea how I obtained them, they were either given to me in a batch of stuff or I've picked them up for peanuts at a radio rally. I certainly wouldn't have ordered them myself.
IanRogers
Posted: 04:39pm 22 May 2023
I'm hardly ever up that way.. Once when I was working at the ferry port.  But I'm not far in Oldham..
Having said that, I don't really know what I'd do with them. I normally program Pic's nowadays.
Posted: 04:50pm 22 May 2023
  IanRogers said  But I'm not far in Oldham..
Where the A6 goes cobbled .
IanRogers
Posted: 04:55pm 22 May 2023
I bet if you dig down three or four inches the A6 will still have the cobbles underneath LOL..
Posted: 05:00pm 22 May 2023
Cobbles may be good hardcore :)
edit: oh good, didn't get censored
Edited 2023-05-23 03:00 by JohnS
