Local Time 22:54 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PM:VGA - FILES at Cmd Prompt erases variables?
Posted: 07:00am 21 May 2023
Hi all.
It is common for me during debug, to stop at the console with either CTRL-C or a simple END command in the code, where I can then examine strings and variables to confirm that they are what they should be.
This works.
However, if I ever call FILES, from that point on, ALL variables(strings or other) seem to be erased and are no longer in effect.  IE: After issuing FILES, any attempt to PRINT F$ kind of thing, results in MMBASIC reporting that F is not declared.
It IS printable at the console BEFORE issuing the FILES command, but after that, it is not.
This may be by design as the interpreter may need the RAM to access and list the files from the SD card, but I would like to check if that is actually the case.
Yes?
No?
Posted: 07:17am 21 May 2023
Yes
Posted: 12:28am 22 May 2023
Thank you.
