Local Time 22:54 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD design aid
PhilP
Posted: 08:36am 11 May 2023
I feel a bit of a lightweight asking this question. Many of my project are based around 2.8 inch 240 x 320 LCD displays showing a lot of textual information. I have tried designing the layout of the screen on graph paper but it is very tedious and I usually give up. In the end I mess about with the position by trial and error taking into account the relative position of items in different font sizes. This is quite time consuming and tedious. Is there any software to lay out a screen or is there a more obvious way of doing this? Thanks
Phil
Quazee137
Posted: 11:07am 12 May 2023
may sound funny but I use a spreadsheet
 sheet one main work space
 sheet two,three ect..  objects to place on sheet one
  only one object per object sheet keeps them uncluttered.
 set row height and column width so you have squares.
 to print the work out I take a screen only of the work area
 at times I will import to Kolorpaint to add circles and triangles.
 Quazee137
 work in times 4 and higher
Edited 2023-05-12 21:10 by Quazee137
Posted: 11:58am 12 May 2023
Many, many years ago I printed out a rectangular grid for the TRS-80 model 1 screen, with column & row numbers. I stuck it onto cardboard then covered it in two layers of the clear plastic self-adhesive film used for book covering. I then wrote on it using "wipe-off" markers. It worked quite well for a number of years.
The problem I think would be that, ideally, you need a screen bigger than the one that you are designing for to work with. You will need to move a cursor round and, probably, have at least an extra line to enter text strings. I wouldn't like to attempt it on an LCD screen, but designing on, say, 640x480 VGA mode 1 wouldn't make it very transferable to a VGA display, I don't think. It might be worth a try, but using manual conversion from X and Y co-ordinates to the LCD program.
Posted: 01:28pm 12 May 2023
I like to lay things out in rows and columns (of varying widths) and then position items as fractions of mm.vres and mm.hres. For instance, with six equal rows and one column starting at zero, another centered at mm.hres/2, and a third right justified at mm.hres-1, the following code would produce this:
Dim string ch
Dim integer i,j,k,fnt,iRows=6,iCols=3
Dim integer b%(15)=(RGB(red), RGB(green), RGB(blue),0,0,0,0,0,0,0,0,0,0,0,0,0)
b%(3)=RGB(Yellow): b%(4)=RGB(cyan)
b%(5)=RGB(gold): b%(6)=RGB(magenta): b%(7)=RGB(brown): b%(8)=RGB(pink)
b%(9)=RGB(salmon): b%(10)=RGB(orange):b%(11)=RGB(grey):b%(12)=RGB(white)
b%(13)=RGB(lightgrey): b%(14)=RGB(beige): b%(15)=0 ' black
fnt=4
ch="A"
CLS
For i=0 To iRows-1
 Text 0,i*(MM.VRes/6),ch+Str$(i)+"  ",,fnt,3,b%(2),b%(j Mod 16)
 Inc j
 Text MM.HRes/2,i*(MM.VRes/6),Chr$(Asc(ch)+1)+Str$(i)+"  ",C,fnt,3,0,b%(j Mod 16)
 Inc j
 Text MM.HRes-1,i*(MM.VRes/6),Chr$(Asc(ch)+2)+Str$(i)+"  ",R,fnt,3,0,b%(j Mod 16)
 Inc j
Next i
This is on an ILI9488 with 480x320 resolution, but should work on an ILI9341 with 320x240 (maybe with change of scaling) or VGA or MMB4W.
Or like this:
Edited 2023-05-12 23:35 by lizby
IanRogers
Posted: 01:42pm 12 May 2023
I normally create a picture in windows edit.. Use a font that is close to the size I use. Then I cam just watch the mouse coordinates that way I can position everything where I need to.
Edited 2023-05-12 23:42 by IanRogers
I'd give my left arm to be ambidextrous
Posted: 01:44pm 12 May 2023
  IanRogers said  I normally create a picture in windows edit
What is "windows edit"?
NPHighview
Posted: 01:55pm 12 May 2023
Powerpoint for me - I specify a layout (in inches, sorry) that corresponds to the screen dimensions (4.8"x3.2" for the 3.5" WaveShare Pico Eval Board LCD), then use the guides, rulers, size, and grouping tools to position items. Fixed (non-kerned, non-proportional) fonts come from the font selection drop-down, and I choose a font size that corresponds to the MMBasic fonts. I zoom the layout to fill my screen, and have at it.  The guides show me where things are on the screen.
PhilP
Posted: 07:05pm 13 May 2023
Thanks everyone for useful and interesting ideas. I am particularly keen on getting the X, Y co-ordinates so I will try drawing the layout in Powerpoint and use the mouse cursor position to convert to LCD positions.
Phil
IanRogers
Posted: 04:21pm 14 May 2023
Sorry. Windows Paint!  right clicking is always Edit.
I keep telling everyone. I'm getting old.
Andrew_G
Posted: 11:40pm 14 May 2023
This may be a question for TassyJim?
Jim's FontTweak can already display a 480x320 grid that allows you to turn cells on/off.
Can it be modified to:
- have column/row IDs (ie x / y)
- display text as per MMBasic fonts
- maybe even draw a line/circle etc.
- save the display in a way that provides meaningful input to MMBasic ???
Jim has more than enough on at present (especially with good weather) but it is just a thought?
In the absence of such a tool I get by with:
- setting screens up as small (ie quick to load) programs until they are ready to be pasted into the main code
- knowing the width/height of each font (in the manual)
- in the TEXT etc commands; use temporary variables so a small change can be applied to multiple TEXTs etc.
- using the Console command mode to trial location options.
Cheers,
Andrew
Posted: 01:58am 15 May 2023
It is something that I have thought about but not with a lot of enthusiasm.
I am not a GUI user/create so not the best to ask but I would look at MMB4W.
You should be able to create elements and save them as sprites. This lets you move them around easily.
If sprites don't work, just redraw as you move elements.
Either work at 1-1 scale or for those of us with tired eyes, use the built in commands to create the elements at 1-1 in a corner of the window.
At a regular interval, copy and paste them to a 'magnifier' area at 1-2 or 1-4 scale.
A simple menu to select the element and arrow keys to move it.
Posted: 07:33am 15 May 2023
It would look something like this with MMB4W:
 OPTION DEFAULT INTEGER
 MODE 16
 magstart = 400
 zoom = 3
 DIM cpos(20,5)
 ctrl = 2
 cpos(1,1) = 100
 cpos(1,2) = 50
 cpos(2,1) = 100
 cpos(2,2) = 100
 cpos(2,3) = 150
 cpos(2,4) = 40
 cpos(3,1) = 100
 cpos(3,2) = 150
 cpos(3,3) = 50
 cpos(3,4) = 25
 DO
   GUI CAPTION #1, "Speed (rpm)", cpos(1,1), cpos(1,2)
   GUI NUMBERBOX #2, cpos(2,1), cpos(2,2), cpos(2,3), cpos(2,4),RGB(WHITE),RGB(BLACK)
   CTRLVAL(#2) = 100
   GUI BUTTON #3, "RUN", cpos(3,1), cpos(3,2), cpos(3,3), cpos(3,4), 0, RGB(RED)
   FOR h = 1 TO 320*zoom
     FOR v = 1 TO 240*zoom
       col = PIXEL(h\zoom+1,v\zoom+1)
       PIXEL h+magstart,v, col
     NEXT v
   NEXT h
   DO
     k$ = INKEY$
   LOOP UNTIL k$<>""
   SELECT CASE k$
     CASE CHR$(128) ' up
       INC cpos(ctrl,2), -5
     CASE CHR$(129) ' down
       INC cpos(ctrl,2) , 5
     CASE CHR$(130) ' left
       INC cpos(ctrl,1), -5
     CASE CHR$(131) ' right
       INC cpos(ctrl,1) , 5
     CASE CHR$(32)
       INC ctrl
       IF ctrl > 3 THEN
         ctrl = 1
       ENDIF
   END SELECT
   GUI DELETE ALL
 LOOP
space bar to change controls.
arrow keys to move controls.
That's all folk...
Posted: 09:57am 16 May 2023
I have been sucked in. Silly me...
Something workable in a few days but this should run on any LCD or MMB4W
Don't have a VGA to test.
It will be integrated into MMEdit
This is missing most of the initial setup code.
 ' GUI design
' TassyJim May 2023
 DIM move = 1
 DIM ctrl = 1
 DIM grid = 5
 DIM n, a = 2, b = 1
 DIM cpos(20,4)
 RESTORE position_data
 DO
   INC n
   READ cpos(n,1),cpos(n,2),cpos(n,3),cpos(n,4)
 LOOP UNTIL cpos(n,1) = -1
 CLS
 printit "Space = next, G = grid, Z = zoom size, S = save data"
 DO
   ' your GUI elements start here
   grid = 5
   maxctrl = 3
   CTRLVAL(#2) = 100
   ' end of your GUI elements
   DO
     k$ = INKEY$
   LOOP UNTIL k$<>""
   SELECT CASE k$
     CASE "g","G" ' toggle grid
       move = grid + 1 - move
       printit "Step size "+STR$(move)
     CASE CHR$(128) ' up
       INC cpos(ctrl,a), -move
       cpos(ctrl,a) = (cpos(ctrl,a)\move)*move
       IF cpos(ctrl,a) <4 AND b = 3 THEN cpos(ctrl,a) = 4
       IF cpos(ctrl,a) <0 AND b = 1 THEN cpos(ctrl,a) = 0
       INC cpos(ctrl,a) , move
       INC cpos(ctrl,b), -move
       cpos(ctrl,b) = (cpos(ctrl,b)\move)*move
       IF cpos(ctrl,b) <4 AND b = 3 THEN cpos(ctrl,b) = 4
       IF cpos(ctrl,b) <0 AND b = 1 THEN cpos(ctrl,b) = 0
       INC cpos(ctrl,b) , move
     CASE "z","Z"
       b = 4-b ' b = 1 or 3
       a = 6-a ' a = 2 or 4
       IF b = 1 THEN
         printit "Location"
       ELSE
         printit "Size"
       ENDIF
     CASE CHR$(32)
       INC ctrl
       IF ctrl > maxctrl THEN
         ctrl = 1
       ENDIF
       printit "Control "+STR$(ctrl)
     CASE "s","S" ' save position data
       FOR n = 1 TO maxctrl
         printit "DATA "+STR$(cpos(n,1))+","+STR$(cpos(n,2))+","+STR$(cpos(n,3))+","+STR$(cpos(n,4))
       NEXT n
   END SELECT
   GUI DELETE ALL
 LOOP
SUB printit txt$
 IF MM.DEVICE$ = "MMBasic for Windows" THEN
   TEXT 10, MM.VRES - 30, txt$+SPACE$(50)
 ELSE
   PRINT txt$
 ENDIF
END SUB
position_data:
 DATA 65,30,0,0
 DATA 65,75,65,30
 DATA 90,115,75,40
 DATA 150,100,100,50
 DATA 150,100,100,50
 DATA 150,100,100,50
 DATA 150,100,100,50
 DATA 150,100,100,50
 DATA 150,100,100,50
 DATA 150,100,100,50
 DATA -1,-1,-1,-1
Arrows to move or resize,
G to toggle slow or aligned to grid,
space to change control
z to toggle move or resize.
s to save (not doing much yet)
Andrew_G
Posted: 08:42pm 16 May 2023
Hi Jim,
Not at the expense of other "stuff"!
I won't get a chance to play for a day or so (more decisions re the build - spent yesterday driving around Melbourne looking at render).
Many thanks,
Andrew
Posted: 11:01am 18 May 2023
Making progress.
All the steps seem to be working. I 'just' need to do the instructions.
 ' GUI design
 DIM move = 1
 DIM ctrl = 1
 DIM maxctrl,n, a = 2, b = 1
 DIM cpos(20,5)
 DO
   INC n
   READ cpos(n,1),cpos(n,2),cpos(n,3),cpos(n,4),cpos(n,5)
 LOOP UNTIL cpos(n,1) = -1 AND cpos(n,2) = -1
 maxctrl = n-1
 CLS
 Txt$ = "Space = next, G = grid, Z = position/size, +- = size text, S = save data"
 'RUN_ONCE
 ' place any code needed for the GUI elements here eg string$ assignments
 STRING$ = " Hello World"
 caption$ = "Start"
 DO
   'GUI_ELEMENTS
   GUI BUTTON #1, caption$, cpos(1,1), cpos(1,2), cpos(1,3), cpos(1,4) , RGB(LILAC) ,RGB(BLACK)
   GUI BUTTON #2, "Stop", cpos(2,1), cpos(2,2), cpos(2,3), cpos(2,4) , RGB(WHITE) ,RGB(MYRTLE)
   GUI CHECKBOX #3, "Tick me", cpos(3,1), cpos(3,2) , cpos(3,4) , RGB(GREEN)
   GUI RADIO #4, caption$, cpos(4,1), cpos(4,2), cpos(4,4), RGB(GREEN)
   GUI LED #5, caption$, cpos(5,1), cpos(5,2), cpos(5,4), RGB(RED)
   TEXT cpos(6,1), cpos(6,2), STRING$ ,cm , #2 , cpos(6,5) , RGB(WHITE) , RGB(BLACK)
   TEXT cpos(7,1), cpos(7,2), STRING$ ,cm , #2 , cpos(7,5) , RGB(BLUE) , RGB(YELLOW)
   ' Control loop
   'LOOP_CONTROL
   DO
     printit
     txt$ = ""
     DO
       k$ = INKEY$
     LOOP UNTIL k$<>""
     redrawit = 1
     SELECT CASE k$
         'move = grid + 1 - move
           IF move = 1 THEN : move = 5
           ELSEIF move = 5 THEN : move = 10
         ELSE : move = 1 : ENDIF
         redrawit = 0
       CASE CHR$(128) ' up
       CASE "+"
         INC cpos(ctrl,5), 1
         IF cpos(ctrl,5)>10 THEN cpos(ctrl,5)=10
       CASE "-"
         INC cpos(ctrl,5), -1
         IF cpos(ctrl,5)<1 THEN cpos(ctrl,5)=1
       CASE "z","Z"
         redrawit = 0
       CASE CHR$(32)
         INC ctrl
           ctrl = 1
         ENDIF
         ' Txt$ = "Control "+str$(ctrl)
         redrawit = 0
           OPEN "loopcontrol.bas" FOR output AS #1
           PRINT #1, "position_data:"
             PRINT #1, "DATA "+STR$(cpos(n,1))+","+STR$(cpos(n,2))+","+STR$(cpos(n,3))+","+STR$(cpos(n,4))+","+STR$(cpos(n,5))
             IF cpos(n,1) = -1 THEN EXIT FOR
           NEXT n
           PRINT #1,"DATA -1, -1, -1, -1, -1"
           CLOSE #1
           txt$ = MM.INFO$(DIRECTORY)+"loopcontrol.bas"
           SYSTEM txt$
         ELSE
           PRINT "position_data:"
             PRINT "DATA "+STR$(cpos(n,1))+","+STR$(cpos(n,2))+","+STR$(cpos(n,3))+","+STR$(cpos(n,4))+","+STR$(cpos(n,5))
           NEXT n
           PRINT "DATA -1, -1, -1, -1, -1"
           PRINT
         ENDIF
         redrawit = 0
     END SELECT
   LOOP UNTIL redrawit = 1
   GUI DELETE ALL
   CLS
 LOOP
SUB printit
 IF txt$="" THEN
   IF b = 1 THEN
     txt$ = "Control "+STR$(ctrl)+", Step size "+STR$(move)+", X="+STR$(cpos(ctrl,1))+", Y="+STR$(cpos(ctrl,2))
   ELSE
     txt$ = "Control "+STR$(ctrl)+", Step size "+STR$(move)+", W="+STR$(cpos(ctrl,3))+", H="+STR$(cpos(ctrl,4))
   ENDIF
 ENDIF
   TEXT 10, MM.VRES - 30, txt$+SPACE$(40)
 ELSE
   PRINT CHR$(27)+"[1A"+txt$+SPACE$(40)
 ENDIF
 txt$=""
END SUB
position_data:
 DATA 70,30,70,20,1
 DATA 140,30,70,20,1
 DATA 80,150,70,20,1
 DATA 245,108,145,15,1
 DATA 110,80,70,15,1
 DATA 135,205,70,20,2
 DATA 114,114,70,20,1
 'USER_DATA
 ' place your resources here. Fonts etc.
Tested on MMB4W and picomite with LCD.
Posted: 05:54am 19 May 2023
MMEdit V5.1.4 is available and it contains the GUI design feature.
See the MMEdit5 thread
Andrew_G
Posted: 07:28am 19 May 2023
Hi Jim,
Thanks so much for this. I've updated to it but will play properly tomorrow.
I'll post any comments on the MMEdit5 thread.
Cheers,
Andrew
