Local Time 23:00 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMbasic : no overflow underflow error ?
vincenthimpe
Posted: 06:31pm 10 May 2023
it looks like there is no error on overflow.
Option default integer
Option explicit
Dim integer x=1
t: Print x
  x=x*2
  pause 100
   GoTo t
-snip-
36028797018963968
72057594037927936
144115188075855872
288230376151711744
576460752303423488
1152921504606846976
2305843009213693952
4611686018427387904
-9223372036854775808
0
0
0
0
0
0
THe program does not stop on overflow and keeps going with the variable stuck at 0 ...
There should be an error thrown for overflow/underflow that can be trapped with an "on error "
Posted: 08:35pm 10 May 2023
To be fair, that's a very unusual situation. In almost all cases a programmer will be deciding on boundaries and checking for them as part of the program. At least they should be. You should always check that there are no more green bottles standing on the wall and that you haven't loaded your six-shooter with 10000000 bullets. :)
vincenthimpe
Posted: 09:07pm 10 May 2023
  Mixtel90 said  To be fair, that's a very unusual situation.
every Basic (or other programming language , including assembly) has an overflow detection mechanism. (assembly has a flag in the cpu)
The problem is that the contents first overflow negative , then lock to 0. This is unwanted behaviour from the interpreter. An error condition needs to be thrown when a mathematical overflow / underflow occurs. That way i can trap this with an "on error" clause.
Besides , it works with floats, so it should work in integers as well
Value     :     2.47182806e+307
Error No  :     0
Error msg :
Value     :     4.943656121e+307
Error No  :     0
Error msg :
Value     :     9.887312242e+307
Error No  :     0
Error msg :
[6] t: x = x*2
Error : Overflow
Posted: 09:12pm 10 May 2023
  Quote  it works with floats, so it should work in integers as well
It doesn't, it won't. If this doesn't suit then don't use MMBasic
Posted: 09:50pm 10 May 2023
Unfortunately it doesn't and is unlikely to do so in the near future unless you'd like to checkout the source code and add the feature for yourself.
MMBasic has many fine features, but it's error handling is a little weak. I dare say this is a legacy of having originally required a relatively small footprint so as to be able to run on a previous generation of microcontrollers.
I hope you will judge it on its merits and perhaps stay around and tell us about your project.
Edited 2023-05-11 07:57 by thwill
vincenthimpe
Posted: 11:36pm 10 May 2023
That's a bit of a bummer.
zeitfest
Posted: 12:29am 11 May 2023
Maybe check thePOSIX  standard reporting. Most of it is applicable for larger systems of course but there are a number of conditions that small micro systems probably should manage. I think it impacts commercial insurability and so on.
Posted: 10:03am 12 May 2023
  zeitfest said  Maybe check thePOSIX  standard reporting. Most of it is applicable for larger systems of course but there are a number of conditions that small micro systems probably should manage. I think it impacts commercial insurability and so on.
Bearing in mind MMBasic is standalone (no OS), with both RAM & flash memory very limited and so on, which part(s) of POSIX do you mean?
Posted: 10:29am 12 May 2023
  vincenthimpe said  every Basic (or other programming language , including assembly) has an overflow detection mechanism
How do you think C does it?
Bear in mind that if MMBasic had originally been written in assembly it would likely not be on the ARM devices at all let alone so many, or on Windows & Linux...
  vincenthimpe said  Besides , it works with floats, so it should work in integers as well
It's a reasonable thing to hope, but if you choose to use INTEGERs in MMBasic they don't work that way.  So you either live with that or don't use INTEGERs.
(Or tweak the code but there's quite a bit - to make sure you find every case.)
edit: if you do change the code successfully and it's not much bigger or slower, maybe it will be included in the future
Edited 2023-05-12 23:58 by JohnS
zeitfest
Posted: 03:52am 13 May 2023
I think it would be good to have a small standard API for error handling in small systems.  [not that I have done much of it  - utter hypocrisy here !!    ]
The POSIX standard is mostly for much larger systems but it does suggest things like
Floating Point Exceptions
Segmentation / Memory Violations
Illegal Instructions
Usually a processor has register(s) error flags that are set by the hardware and checked, other things can be checked in programming and IDE's  usually provide functionality along those lines. Most small system applications check for possible runtime errors as well of course, I gather MMBasic has a good number of checks anyway as part of being user-friendly.
Although many small systems do not have  a formal OS managing memory and so on, there is practically always a persistent CLI running a user-prompt. It would be maybe easy enough to separate the CLI and interpreter, and set a list of standard errors that an interpreter should catch and flag, the CLI then reporting as needed.
Probably not much point unless trying programs as well as MMBasic I guess. But it would provide an identifiable assurance point.
Posted: 07:01am 13 May 2023
  zeitfest said  Floating Point Exceptions
You get those (if the CPU does them and the ones with MMBasic so far do).
  zeitfest said  Most small system applications check for possible runtime errors as well of course, I gather MMBasic has a good number of checks anyway as part of being user-friendly.
Yes, though not with INTEGER overflow (where you pretty much get what C gives you).
  zeitfest said  there is practically always a persistent CLI running a user-prompt.
Many small-system BASICs, including MMBasic, do not have that (in effect MMBASIC is the CLI when not running a program).
  zeitfest said  It would be maybe easy enough to separate the CLI and interpreter
Not really any point with a small-system BASIC, and inevitably you'd increase the memory overhead.  However, memory is typically a tight constraint already.
The OP was about INTEGER overflow type issues which I don't think POSIX addresses but in any case where the underlying hardware (which is in effect C here!) doesn't provide convenient fast mechanisms for detecting problems then it's tough.
If it was desired to have overflow etc detected with INTEGERs, I suppose the best (fastest) way would be to drop into assembler for such but then the code will be ugly, harder to port and maybe error-prone.
However, avoiding the issues is so easy for the user - just use non-INTEGER i.e. floating point (which is all you have anyway in most BASICs) when doing calculations which might overflow (or for all calculations).
Edited 2023-05-13 17:07 by JohnS
Posted: 07:21am 13 May 2023
Usually a *microprocessor* has stuff like overflow and underflow detection. These are not necessarily present on all *microcontrollers* as they are generally much simpler devices. I don't know what Geoff had to work with when he wrote MMBasic, but I'm pretty sure that all such low level error checking will have been handled by the compiler in some way - but only if there was space for it.
Posted: 07:42am 13 May 2023
If you did want to change it Peter (and I'm not offering an opinion) then GCC provides these builtins:
   __builtin_add_overflow
   __builtin_sub_overflow
   __builtin_mul_overflow
IanRogers
Posted: 07:46am 13 May 2023
I think the overflow has been over estimated. An integer in the basics of binary is a whole number.  The "signed/unsigned" has always been down to  the individual programmer.
C will "warn" in compile time that you "MAY" exceed the integer size. but run time it will not.
I had to do a project "in some other basic" which didn't do negative numbers, so I had to check it myself.
In 8 bit ASM 127 + 2 = 129 but a C compiler sees -2 signed if signed was selected, this is still regarded as a real number in ASM so no flag will be set.
I'd give my left arm to be ambidextrous
Posted: 08:29am 13 May 2023
  Quote  f you did want to change it Peter (and I'm not offering an opinion) then GCC provides these builtins:
Don't work on the Pico as 64-bit ops call ROM subroutines
Posted: 09:00am 13 May 2023
  matherp said  Don't work on the Pico as 64-bit ops call ROM subroutines
Ah, ok, well I'm always surprised that anyone needs to count above 65535 anyway  .
I suppose if someone really needed then that much they could implement "safe" MATH ADD, MATH SUBTRACT and MATH MULTIPLY functions the slow way.
Edited 2023-05-13 19:03 by thwill
