Forum Index : Microcontroller and PC projects : webmite with sd card an TFTP / telnet
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
hi, if i connect a sd card socket to the webmite can i put a file to the sdcard via TFTP or Telnet ? thx Plasma |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6254 |
Hi Plasmamac, I tried Telnet (using Teraterm) and it gives you basically the commandline interface you have through USB serial and COM serial. I have not tested if there is support for X-modem. But I am sure "AUTOSAVE" works, and you can edit. After a AUTOSAVE and <ctrl-Z>, you can always save the file to SD (B:) or A: Volhout PicomiteVGA PETSCII ROBOTS |
That's how MMEdit's file manager does it. You have to install/activate the Windows TFTP application. So, yes, it can be done. TFTP is 'fast' Jim Edit MMEdit has a few problems with telnet so it is not very user-friendly at this stage. I have lots of work to do... Edited 2023-05-10 18:07 by TassyJim VK7JH MMedit |
