Local Time 03:12 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Need Help. How to compile the picomite source under win 10
Plasmamac
Posted: 05:12pm 27 Apr 2023
HI,
Has any other user of this forum been able to achieve success in compiling the PicoMite source code from matherp?  Iam using Win10  but get no success.
i installed
pico visual studio
    visual studio 2022
    python 3.10
    git
    cmake 3.26
    gcc-arm-none-eabi-10-2020-q4-major-win32   ! maybe this is the fault,
                                                 matherp use GCC 12.2.1 arm-none-eabi
after some frustrating days to try everthing working i get these erroe code
[proc] The command: "C:\Pico\Pico SDK v1.5.0\cmake\bin\cmake.EXE" --no-warn-unused-cli -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=TRUE -DCMAKE_BUILD_TYPE:STRING=Debug "-DCMAKE_C_COMPILER:FILEPATH=C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin\arm-none-eabi-gcc.exe" "-DCMAKE_CXX_COMPILER:FILEPATH=C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin\arm-none-eabi-g++.exe" "-SC:/pico mite/PicoMite-main/PicoMite" "-Bc:/pico mite/PicoMite-main/PicoMite/build" -G "nmake makefiles" exited with code: 1
if anyone can help i will setup a Teamviewer connection.
Thanks a lot
Plasma
Posted: 09:53pm 27 Apr 2023
I used this on W11:
https://github.com/raspberrypi/pico-setup-windows
and then installed GCC 12.2.1 and altered things to suit.
Removing my failed attempts fully was the hard part.
Note I know nothing abut all these mysterious tool chains so I am the last person to offer sensible help.
I have managed the standard picomite. Not the WEB or VGA but will try the VGA soon.
edit:
I 'think' the only change needed once I had cleared out the old installs was to edit
"C:\Users\Jim\AppData\Local\CMakeTools\cmake-tools-kits.json" to point to the 12.2 version.
Edited 2023-04-28 08:22 by TassyJim
Plasmamac
Posted: 10:35pm 27 Apr 2023
HI ,
thanks Tassyjim , can you show me a link to the gcc 12.2.1?
i will setup a new virtual maschine , because so many failed tests here also.
i fear i have broken my windows
thx a lot again
Plasma
Posted: 10:45pm 27 Apr 2023
https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads
