Local Time 03:12 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM.INFO?
IanRogers
Posted: 06:18pm 25 Apr 2023
Can someone give me the several examples of MM.INFO as nothing seems to return anything.
The manual said... MM.INFO(drive) etc... I have tried nearly every iteration ( I say nearly as clearly the right one eludes me..).
Its my first go at V 5 07 06 on a pico and I was trying to obtain fee space left on B:
Ian
I'd give my left arm to be ambidextrous
JanVolk
Posted: 07:23pm 25 Apr 2023
Ian,
Possibly a syntax error?
So MM.INFO is a function ? or use Print after > to get what back, ? MM.INFO$(drive) returns A: or B:.
The B: drive is SD card only and A: is Flash drive.
Jan
Posted: 08:08pm 25 Apr 2023
> option list
PicoMiteWEB MMBasic Version 5.07.07RC3
OPTION AUTORUN ON
OPTION COLOURCODE ON
OPTION DISPLAY 40, 110
OPTION WIFI Omnibus-Av2_EXT2, *********
OPTION TCP SERVER PORT 80, 6000
OPTION TELNET CONSOLE ON
> ?mm.info(disk size)
618496
> ?MM.INFO(VERSION)
5.0707
Posted: 09:02pm 25 Apr 2023
This comes up often so I guess the next manual needs to explain that it will only return a value to the console with PRINT.
Posted: 09:54pm 25 Apr 2023
I think all the MM.INFO things are read-only variables. It makes sense that you can't see them in the console without a PRINT command. However, they can also be read within a program - and not necessarily printed. The manual does, in fact, refer to them as "Predefined read only variables".
Posted: 10:02pm 25 Apr 2023
"The manual does, in fact, refer to them as "Predefined read only variables"."
Yes, yet some don't realize that means at the console you need Print.
JanVolk
Posted: 12:21am 26 Apr 2023
Correct MM.INFO( is a function and PEEK, Time$, Date$ are also functions (Read) so we get something back from the microcontroller. Try List Functions for an overview.
And ?, Print, Poke is a command to the microcontroller (Write). Try List Commands for an overview. And after > first comes a command to tell the microcontroller what to do.
Jan
IanRogers
Posted: 06:59am 26 Apr 2023
Thanks everyone.
I didn't use the ? to print
> ?MM.INFO yields "0"
> MM.INFO yields "unknown command"
So ? is the actual command..  Now I know.
Posted: 07:21am 26 Apr 2023
? is just a short name for PRINT.
