Local Time 23:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Remote logging using MMB4W and the WebMite
Posted: 06:13pm 22 Apr 2023
I have just implemented a simple Telnet client in MMB4W. This allows you to talk to the Web version of the PicoMite (WebMite) over the internet all without leaving Basic.
I've also implemented OPTION ESCAPE to make things even easier.
In the example I just list a file remotely but you could execute a program, and read the output or enter commands at the command prompt to do things like read an analogue voltage
MMB4W V5.07.03b16
MMBasic.zip
e.g.
option escape ' turn on escape codes
telnet client open "192.168.1.147",23 ' open a telnet connection to the Webmite
telnet send "list all \qsolar_eclipse.bas\q\r\n" 'send any sort of command to the Webmite
timer=0
do
telnet receive s$ 'read anything the Webmite has returned
if len(s$) then
print s$;
timer=0
endif
loop until timer>100
telnet close 'close the telnet connection
Edited 2023-04-23 04:15 by matherp
