Local Time 23:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Start your engines!
Posted: 08:55am 12 Apr 2023
https://goodereader.com/blog/e-paper/e-ink-spectra-6-the-full-color-epaper-for-digital-signage
Posted: 01:33pm 12 Apr 2023
CaptainBoing: good find
"E Ink [...] has launched E Ink Spectra 6 ePaper display [...] This first full-colour screen from the company is intended to provide a print-quality replacement for paper signs, including posters, POP displays, signage, and other in-store advertising."
while the mass-market applications seems to mostly revolve around advertising, i could see this as a great spinoff opportunity for E-Magazines to finally flourish. at the moment electronic-magazines are limited by the (6") size and monochrome constraints of the average e-reader (for most folks, an Amazon Kindle), with the only alternative being the publisher releasing a .PDF version of their copy into the wild where it can be (wildly) copied. but with COLOUR ePaper displays maturing, and once a size closer to A4 is achievable, then we will be able to see DRM'ed magazine content sent directly to a subscriber's device.
along with ever growing flash density, it will become practical for one to purchase (for instance) the complete back-catalog of every Silicon Chip Magazine on an A4-sized device. or a complete Encyclopedia Britannica, or a complete copy of Wikipedia (approx 100Gb as of april 2023).
rob   :-)
Posted: 01:37pm 12 Apr 2023
You are assuming the update rate may be sensible. Based on the article and the specified use cases I suspect it could be many seconds with who-knows-what artefacts during refresh
Edited 2023-04-12 23:41 by matherp
Posted: 02:03pm 12 Apr 2023
very true - I couldn't really find any info other than this article. I have see tri-colour e-ink displays (red white & black) and they go through all sorts of contortions when the image changes. OK for fairly static stuff (like what the displays are aimed at) but can't even deal with a reasonable fast changing area (like the time with seconds)
but... the door is open - it can only get better
Edited 2023-04-13 00:04 by CaptainBoing
