Local Time 23:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help needed with SD card in Picomite
charlielamus
Posted: 02:46pm 11 Apr 2023
Hello all,
I am quite new to all this vintage computing lark (at least, I last programmed a 6502 when it wasn't vintage computing), and I am cutting my teeth with a Picomite VGA on a breadboard.
I am having problems connecting my SD card reader - a no-name breakout board from Amazon - to the Picomite.
Once connected, it will happily change to drive B, but on giving the 'files' command it says there is no SD card connected. If I try holding the card in a fraction with my finger, it says that there is no FAT filesystem on it, but does at least say "SD card removed" when I take the card out.
I have checked and rechecked the SPI connections, tried multiple cards, and formatted them in Fat 16, fat 32 and at various allocation sizes. Nothing seems to work. I have also tried other SPI pins on the Pico to no avail.
Any ideas?
Thank you!
Posted: 03:07pm 11 Apr 2023
Does the breakout have components on it? There shouldn't be any. Many of them are designed for level changing 5V to 3.3V for Arduino and are not suitable.
charlielamus
Posted: 03:10pm 11 Apr 2023
Yes indeed it does - a bunch of tiny surface mount components which may be resistors. And the Voltage in pin is labelled 3.3V. is that the wrong thing? I thought that the Pico operated on 3.3v?
charlielamus
Posted: 03:13pm 11 Apr 2023
This is the one I have:
Posted: 03:25pm 11 Apr 2023
For simplicity set (assuming VGA firmware)
OPTION SYSTEM SPI GP22, GP10,GP11,GP12
You are then going to connect as follows:
GP10 - CLK
GP11 - CMD
GP12 - DAT0
GP22 - D3
GND - GND
3.3 - 3.3
But first buzz out which resistors connect to these pins and whether they are series resistors or pullups. If pullups remove them. If series resistors remove and replace with a solder blob. They look like pullups so R1-R7 can all be removed. Pullups are used for SDIO connection (and for this they are even the wrong value). They should not be used for SPI connections
Edited 2023-04-12 01:28 by matherp
charlielamus
Posted: 03:28pm 11 Apr 2023
Thank you! I will try that
I can quite happily identify which resistor bells to which pin but what is the difference between series resistors and pull ups, and how can I tell? I thought pull up resistors *were* in series with the pins?
Martin H.
Posted: 03:34pm 11 Apr 2023
  charlielamus said  Thank you! I will try that
PullUp has one Side is connectet to +3.3V andt the other side to the Data Pin...
If they are Serial they connect the Data Connection from the Board  with the Data Connection on the Card Reader, so they are inside the data line.
Edited 2023-04-12 01:37 by Martin H.
'no comment
Posted: 03:35pm 11 Apr 2023
pullups - one end connected to 3.3V
series - one end to the edge connector, the other to the socket
Posted: 03:41pm 11 Apr 2023
It looks to me as if it should work, in theory. Those resistors look like 10k pullups. Additionally there's a supply bypass capacitor and a 1k/LED across the supply.
As a matter of interest, the micro SD card modules that I got from ebal also have 10k pullups - and they work. Maybe I'm just lucky?
I assume you are using the 3V3 supply from the PicoMite?. You could try adding a 2R2 series resistor then an electrolytic bypass capacitor of 10-47uF. Normally we don't need to filter the supply for micro SD cards.
Edited 2023-04-12 01:43 by Mixtel90
Posted: 09:39pm 11 Apr 2023
It looks like this card is designed to work with 3.3V micros and the Raspberry Pi Pico in particular.
See this reference: https://learn.sb-components.co.uk/MicroSD-Breakout
So the problem is not with the breakout card.
It would be best to do as Peter suggested...
Connect as follows:
 GP10 - CLK
 GP11 - CMD
 GP12 - DAT0
 GP22 - D3
 GND - GND
 3.3 - 3.3
Then enter the following at the command prompt: OPTION SYSTEM SPI GP22, GP10,GP11,GP12
Make sure that you entered the command correctly and check that your connections are secure and reliable.
JanVolk
Posted: 10:44pm 11 Apr 2023
Charlielamus,
Try a somewhat smaller SD card, because 128GB is a bit large. I myself have the best experience with micro SD cards of 4-32 GB. And 32GB is a cheap standard size.
First check with an external card reader if you can write and read something along the way and create a few directories and put some .bas files in them. Then you know for sure that there is something on it.
Jan
JanVolk
Posted: 11:03pm 11 Apr 2023
Charlielamus,
Have a look on AliExpress at Arduino Micro Card Reader. I really like these with 6 pins. But many other sellers.
2pcs/lot TF Micro SD Card Module Board Mini SD Card Module Memory Module For Arduino Arm Avr
€ 0.62 / lot (2 pieces)
Price includes VAT
Number:
9977 lots available
Will be shipped to
Netherlands
Shipping: €1.42
Jan
JanVolk
Posted: 11:12pm 11 Apr 2023
Charlielamus,
Some text has been filtered because it contained prices, but the message is clear.
Jan
