Local Time 23:27 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico doesn't like to be touched by i.e. probes
nbrok
Posted: 04:55am 07 Apr 2023
Still experimenting with the pico and discovered this:
I wanted to check the voltage of the powersupply on VSYS and 3.3V with a multimeter (digital) and spontaneous the pico resets. It is only touching one of the powerlines that causes this behavior. Is the noise made by the on board regulator so loud that a probe functions as an antenna and destabilize the powerline that causes a power-on reset? A screwdriver (isolated) gives the same result...
My conclusion and opinion Pico's are very sensitive devices....
Touching by fingers doesn't cause anything..... (fingers have a high resistance)
Strange isn't?
Greetings,
Nick de pe1goo
Posted: 05:08am 07 Apr 2023
Put a 10k resistor from RUN pin to 3.3V and a 0.01 capacitor from RUN to GND.
nbrok
Posted: 05:34am 07 Apr 2023
  TassyJim said  Put a 10k resistor from RUN pin to 3.3V and a 0.01 capacitor from RUN to GND.
You mean a 0.01 uF capacitor (10nF)? I hope.
I'll try your suggestion... Thanks.
Greetings,
Nick de pe1goo
Posted: 05:37am 07 Apr 2023
Yes 0.01uF
I should proof read better.
