Local Time 23:27 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Display for Picomite
Plasmamac
Posted: 06:05am 04 Apr 2023
What is the best Display for the Picomite, with support for all features and speed?
Thx
Plasma
Posted: 06:57am 04 Apr 2023
SSD1963
+ Fast, supports Touch. Available up to medium sizes. All LCD commands supported.
- If you can afford the eye-watering prices. Uses most of the pins on the PicoMite.
VGA
+ Fast. Available up to large sizes (very large if you feed a telly).
- Doesn't support Touch. Can be bulky.
ILI9341
+ Supports Touch. All LCD commands supported. Availability isn't bad.
- Not available in large sizes. Not particularly fast, especially when scrolling text.
It depends on what you need. You have to compromise as there is nothing that excels at everything.
Posted: 07:18am 04 Apr 2023
  Quote  It depends on what you need.
Posted: 12:20pm 04 Apr 2023
My favorite: ILI9488. It's SPI, but I find the speed for using the editor workable, and the screen size is OK if you can read the letters without difficulty.
Just make sure you get proper ones with touch and not the shift-register maladaptation.
But of course it depends on what you want.
Edited 2023-04-04 23:15 by lizby
stanleyella
Posted: 02:59pm 04 Apr 2023
@lizby
Hi, I got an ili9488, it's a plug in replacement for ili9341 except the sd card pins are 2 cm further apart.
I got a tron game working with touch and play tone and when setting up the display files showed something  so thought sd card ok but when I tried play wav "b:/t1" it says sd card not found.
I had to use a 580R resistor in the miso from the display to touch and sd card miso "GP16" to make the display work but maybe a problem with sd card.
my board takes ili9341 and ili9488 so reverted to ili9341, which seems faster and sd card works.
ili9488 is nice display but there's problems with it from forum posts.
Posted: 08:59pm 04 Apr 2023
If you search the other threads on ILI9488 you will see that the 680R can cause problems with the SD card. The alternative is shown there - a diode and 10k resistor.
The diode replaces the 680R, cathode to SDO on the display and anode to MISO on the Pico. The 10k goes from LCD_CS to MISO on the Pico.
Posted: 09:59pm 04 Apr 2023
Correction to above, diode wrong way round.
The diode replaces the 680R, anode to SDO on the display and cathode to MISO on the Pico. The 10k goes from LCD_CS to MISO on the Pico.
See Here.
https://www.thebackshed.com/forum/ViewTopic.php?TID=15523&PID=197310#197310#197310
The ILI9488 is a little slower as there is double the number of pixels to send for a full refresh.
ILI9488 - 480 x 320 = 153,600 pixels x 18 bits/pixel
ILI9341 - 320 x 240 = 76,800 pixels x 16 bits/pixel
Edited 2023-04-05 17:08 by phil99
stanleyella
Posted: 01:48pm 05 Apr 2023
Thanks phil99 for the link, I posted a breadboard version in that thread.
with a diode and resistor does it All work ie sd card graphics and touch?
Bouncing 16 16x16 sprites seems slower visually with ili9488 than ili9341.
I'll retry ili9488, joys of stripboard over pcb.. easily adapted.
Will a blob of solder short the 1K resistors or will they come off the board and is it reversible with a solder sucker?
Edited 2023-04-06 00:05 by stanleyella
Posted: 02:01pm 05 Apr 2023
  Quote  ILI9488 - 480 x 320 = 153,600 pixels x 18 bits/pixel
ILI9488 - 480 x 320 = 153,600 pixels x 24 bits/pixel (18 used)
stanleyella
Posted: 05:37pm 05 Apr 2023
I tried the resistor/diode solution and it seems to work. touch and graphics and play wav from sd card.. happy days. thanks.
I didn't short the resistors to sd card on the ili9488 but absent minded did on the ili9341 that was on the board and the resistors melted/disappeared and I got to resolder the links cos sd card don't work now.
It was easy to solder the diode in place of the 680r and add the 10k.
My display was cheap "at the time" and nice for my experimenter board.
