Local Time 23:27 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : USB to PS2
Quazee137
Posted: 04:03pm 03 Apr 2023
Found this last night USB to PS2
  A 2040/pico should be able to do this too.
Posted: 05:22pm 03 Apr 2023
I've seen a photo of it and I refuse to solder it. lol
Well, an RP2040 might be able to do it, but you only have one USB port. It probably needs some C programming or, maybe, python might have some libraries that might help.
Posted: 07:51pm 03 Apr 2023
from a forum posting almost a year ago:
"... the CH375/CH376 also looks like an option, available on a small PCB for around $5 on ebay:
https://www.ebay.com/itm/164195409955
https://www.ebay.com/itm/165027473834
(note: the CH376 may be an updated version of the CH375, and so a better choice)
while the main target is reading USB flash drives, it appears to also produce results from USB keyboards and mouses. it can connect directly to a TTL serial port, and requires to be sent commands and returns packets of data containing keypress information - NOT ASCII codes; some interpretation is required.
see also:
https://github.com/djuseeq/Ch376msc/issues/13
and:
http://www.electronicsfaq.com/2016/11/interface-usb-mouse-to-your-arduino.html "
rob   :-)
Posted: 08:37pm 03 Apr 2023
and this for keyboards
https://www.hobbytronics.co.uk/usb-host-keyboard
LucV
Posted: 02:25pm 04 Apr 2023
Too bad you are all so far away.
There are plenty PS2 keyboards available here in the Netherlands at this company:
Logitech USB keyboard
And trust me: they have plenty in stock.
Edited 2023-04-05 00:39 by LucV
Luc's tech Blog
Posted: 02:45pm 04 Apr 2023
Call those "keyboards"?
This is a keyboard (schematic). More info.
None of that silly serial malarky. And keys that don't wear out because they have no contacts...  :)
