Local Time 23:27 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can this SSD1963 display be used with the PicoMite?
Frank N. Furter
Posted: 06:46am 31 Mar 2023
can this SSD1963 display be used with the PicoMite?
Unfortunately, there are no pin assignments printed or available... :-(
THANKS!
Frank
Posted: 06:57am 31 Mar 2023
Assuming it uses the standard pinout - then yes, see the manual for connection details
Frank N. Furter
Posted: 07:09am 31 Mar 2023
THANKS!
Then I will get the display and try it out!
Frank
Posted: 07:40am 31 Mar 2023
  Quote  Then I will get the display and try it out!
Start by buzzing out connections to the SDcard and xpt2046 chip to see if the wiring corrresponds
Frank N. Furter
Posted: 05:24pm 31 Mar 2023
Thank you very much for the hint! I am very excited when I get the display!
Frank
circuit
Posted: 06:11pm 01 Apr 2023
Perhaps be a little cautious about the orientation of the board; your image shows the circuit board overprint to be upside down.  It is unlikely that this board is intended to be in this orientation.  Perhaps the connector on your board is on the opposite side to the one shown by Peter.  Checking that the ground connection corresponds to the standard diagram might be sensible before making other connections. The connection is likely to be standard but which way up?
Edited 2023-04-02 04:11 by circuit
Frank N. Furter
Posted: 06:40am 03 Apr 2023
@circuit:
You are right! The orientation of the plug is unusual - that's why I asked here first. I have now ordered it - let's see if I can measure the pinout out...
Frank
Posted: 10:52am 03 Apr 2023
You are very brave, ordering a display with no information available. :)
Frank N. Furter
Posted: 12:07pm 03 Apr 2023
Well, the prices are so what exploded! It was a single piece from Germany on Ebay for 35 euro.
At the moment the cheapest cost 45 euros from China!
From Germany even 87 Euro! This is not fun anymore!!!
Wish me luck!!!
Frank
Edited 2023-04-03 22:09 by Frank N. Furter
Posted: 12:48pm 03 Apr 2023
I certainly do! :)
They never were a cheap display.
circuit
Posted: 10:27pm 03 Apr 2023
  Mixtel90 said  I certainly do! :)
They certainly have increased in cost; my last purchase was on Amazon UK when I bought three seven inch units at £22 each - just 18 months ago.
circuit
Posted: 10:30pm 03 Apr 2023
  Frank N. Furter said  @circuit:
Frank
Be aware that some SSD1963 boards have solder jumpers to select the operation of the backlight.  Yours has J1, J2, J3 jumpers which are apparently open.  These may have some functionality in backlight control.
atmega8
Posted: 03:48pm 04 Apr 2023
If i will find some "spare time", i will test this Jumbo Frame;-)
SSD1963 based.....
Frank N. Furter
Posted: 12:13pm 06 Apr 2023
First realization: The display has a default assignment, as posted by Peter!
Let's see when I get to connect the display...
Thanks to all!!!
Frank
Posted: 01:01pm 06 Apr 2023
If you get it working maybe post a link to the supplier.
edit: and if you don't, so people can avoid it.
Edited 2023-04-06 23:51 by JohnS
