Local Time 23:35 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: Another PLAY SOUND bug ?
Posted: 03:17pm 26 Mar 2023
Hi Peter,
I assume I'm just having some sort of mental breakdown, but with b28:
Option Base 0
Option Explicit On
Option Default None
' Why (if uncommented) does this do nothing ?
'Play Sound 1,B,S,256,25
'Do : Pause 1000 : Loop
' But this play Middle-C ?
Pause 1000
Loop
Posted: 03:27pm 26 Mar 2023
Works for me
Posted: 03:37pm 26 Mar 2023
Seriously,
I can see on the scope that it's doing nothing:
> option list
PicoMite MMBasic Version 5.07.07b28
OPTION CPUSPEED (KHz) 252000
OPTION LCDPANEL ILI9341, RLANDSCAPE,GP20,GP21,GP17
OPTION SDCARD GP22
OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3
hitsware2
Posted: 04:15pm 26 Mar 2023
Doesn't
Simply loop the pause 1000 ?
my site
Posted: 04:20pm 26 Mar 2023
  hitsware2 said  Doesn't
Yes it does, I'm just doing something so the program doesn't end. The behaviour is the same (no tone) with just DO : LOOP after the PLAY SOUND.
Posted: 04:29pm 26 Mar 2023
PicoMite.zip
Posted: 04:52pm 26 Mar 2023
  matherp said  PicoMite.zip
Quick test ... same nothing.
Will try again later or tomorrow, but my free time has expired for the moment, need to feed the troops.
Posted: 05:53pm 26 Mar 2023
Oops - sorry, wrong version
PicoMite.zip
Posted: 08:11pm 26 Mar 2023
Thanks Peter, that fixes the issue .
mozzie
Posted: 02:06pm 27 Mar 2023
G'day Peter
I may be asking a bit much from the play sound function, but if I attempt to run two white noise sources:
>Play Sound 1,b,n,1
>Play Sound 2,b,n,2
The Pico locks up / requires power cycle.
Also 3 tones plus white noise source:
>Play Sound 1,b,n,1
>Play Sound 2,b,t,420
>Play Sound 3,b,t,525
>Play Sound 4,b,t,740
If only the left channel is used it functions as normal.
Only require 2 white noise sources to increase output modulation, am I correct in thinking the output is 25% for 1 sound, 50% for 2, 75% for 3 and 100% for all 4?
I imagine there is a fair bit going on in the background to get 8 signals across 2 channels (4x2) simultaneously at 44Khz PWM, including all the lookup table calls etc.
Not surprising the processor load is fairly high
Can you please also advise if you think inverting the 2nd channel:
Poke Short &h40050000,&h09
Is likely to cause any problems.
Running PicoMite 5.070729 but also 5.070728 is the same.
Lyle.
Edited 2023-03-28 00:10 by mozzie
Posted: 02:52pm 27 Mar 2023
Mozzie - what happens at 252MHz CPU speed?
mozzie
Posted: 09:14am 28 Mar 2023
Cheers Peter,
Can confirm at 252MHz 3 white noise sources in parallel or 1 white noise plus 3 sine or triangle.
Also tried 315MHz and 4 white noise or any combination of types.
The answer should have been "jumping off the screen" but couldn't see the woods for the trees
Thanks again for the excellent work .
Lyle.
P.S. so far using Poke Short &h40050000,&h09 to invert the output is working ok but I'll keep testing.
Posted: 09:17am 28 Mar 2023
  Quote  Can confirm at 252MHz 3 white noise sources in parallel or 1 white noise plus 3 sine or triangle.
Have found a fix at normal clock speed 4*noise now works fine on both channels. Watch for b29 being posted
mozzie
Posted: 09:32am 28 Mar 2023
Cheers Peter,
Maybe a thought / suggestion for a later time...
The ability to allow a single Play Sound output at 100% modulation to match play tone, I realise this may take significant work to ensure that if more than 1 sound is running the output is not overdriven, I currently run 1-3 in parallel so not really needed but would be handy.
Thanks again.
Lyle.
Posted: 11:37am 28 Mar 2023
"so far using Poke Short &h40050000,&h09 to invert the output is working ok"
@mozzie
Also works with beta 10.
Are other phase shifts possible? If so it could also be useful for non-audio applications.
A variable speed inverter for a split-phase motor would need 90 deg. An open delta inverter for a 3 phase motor would need 60 deg.
Even if it is only possible to get 180 deg. it would still be handy for a single phase unit.
Posted: 11:42am 28 Mar 2023
  Quote  Are other phase shifts possible? If so it could also be useful for non-audio applications.
This is all already covered in enhancements to the PWM command in the 7.07.07 betas.
  Quote  The PWM command is modified as follows:
PWM channel, frequency, [dutyA] [,dutyB] [,phase] [,deferredstart]
Phase is a new parameter that causes the waveforms to be centred such that a wave form with a shorter duty cycle starts and ends equal times from a longer one. Use 1 to enable this mode and 0 (or omit) to run as normal
The new parameter "deferredstart" when set to 1 prepares the PWM channels as before but does not start the output running. This is to avoid any undesirable startup artefacts
There is a new sub command
PWM SYNC [channel0offset] [,channel1offset] .......[channel7offset]
This initiates the PWM on channels where a deferred start was defined or just syncs exisitng running channels. However, the power comes in the ability to offset the channels one to another (defined as a percentage of the time period as per the duty cycle - can be a float)
You can use an offset of -1 to omit a channel from the synch
Using a negative value for the duty cycle will invert the signal
Edited 2023-03-28 21:58 by matherp
Posted: 12:14pm 28 Mar 2023
Yes it is, and thankyou for that.
It is excellent for modified square wave inverters of all types. Play Tone makes sine wave inverters a piece of cake. Output feedback goes to Play Volume. The 180 deg. trick makes H-bridge driving easier.
More phase shifts would open up more possibilities so was interested to know if Poking other values would work. If not I don't expect you to modify the code. Very few people would use it.
PS. Thanks for the Library. That will be useful to many people.
Posted: 02:09pm 28 Mar 2023
&h40050000 is (in C) 0x40050000 which is PWM_BASE in RP2040 datasheet
See 4.5.3 for the registers.
The web has comments on using the registers, too, e.g. search on
Pico 0x40050000
or
RP2040 0x40050000
Edited 2023-03-29 00:10 by JohnS
stanleyella
Posted: 03:29pm 28 Mar 2023
4.7mH inductors arrived today so built the low pass filter and tried play tone 1000,500,2000
it worked!
Check the photos of the ebay £14 stereo, runs off battery/usb, rechargable. Womans voice says blue tooth mode when turned on then pressing mode says fm mode, pressing again says a u x mode which I'm using, next says u s b mode. Great for the price.
I didn't have the caps for the filter so
68nF was 47nF + 22nF in parallel.
33nF was 22nF + 10nF in parallel,
2.7nF was 2.2nF+ (1nF + 1nF in series) in parallel,
would have been simpler with the right caps... see the photo
but sounds seem ok, I'm happy my soldering with my vision it worked.
Posted: 03:57pm 28 Mar 2023
Copy some cd music to the sd card. You'll be surprised of the sound quality of this 4 dollar pico.
