Local Time 04:19 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : tcp server - what am I doing wrong ?
kaptinvimes
Posted: 09:57am 20 Mar 2023
Having some trouble with Option tcp server port 80
When I send this to picomite
OPTION wifi "xxxx","xxxx"
OPTION tcp server port 80
All is good and web ntp works as expected.
However when I send this
Dim buff%(512)
Dim buff1%(512)
PRINT
PRINT "Your IP address is : " + MM.Info(ip address)
PRINT
WEB tcp interrupt serverstart
  randomnum = Int(Rnd(100)*100)
Loop
Sub serverstart
Local p%, t%
For a%=1 To MM.Info(MAX connections)
    LongString CLEAR buff%()
    WEB tcp READ a%,buff%()edit
    p%=LInStr(buff%(),"GET")
    t%=LInStr(buff%(),"HTTP")
   s$=""
   If (p%<>0) And  (t%<>0) And (t%>p%) Then
     s$=LGetStr$(buff%(),p%,t%-p%+4)
     Print "String is ",s$
   EndIf
   If Instr(s$,"HTTP") Then
     Print "sending page"
     WEB transmit PAGE a%,"second.html"
   EndIf
Next a%
End Sub
Server appears to start Ok however program just hangs and access to ip address in browser is refused.
The only way to get this to work is to send
and then send
Dim buff%(512)
Dim buff1%(512)
PRINT
PRINT
Loop
Sub serverstart
Local p%, t%
   s$=""
   EndIf
   EndIf
Next a%
End Sub
And then all works as expected with web access to ip address established and page accessable. If Picomite is powered down when exercise has to be repeated on restart.
Any ideas gratefully received ! thank you
Posted: 10:33am 20 Mar 2023
The option commands permanently set up the Pico and can only be executed at the command prompt and only need doing once - they should never be included in a program.
kaptinvimes
Posted: 11:56am 20 Mar 2023
Thanks for that, I had forgotten -
(also left Option Autorun On out)
Still all good now
