Forum Index : Microcontroller and PC projects : SSD1306 1.3" OLED Display on SPI
| asknik2022 Regular Member Joined: 26/03/2022 Location: United KingdomPosts: 94 |
Can anyone please help I am trying to setup a 1.3" OLED display using SPI I have a ILI9341 SPi working on these settings: OPTION SYSTEM SPI GP18,GP19,GP16 OPTION LCDPANEL ILI9341, PORTRAIT,GP15,GP14,GP13 if I try and use the SSD1306 on SPI with these settings I dont get any display option system spi gp18,gp19,gp16 option lcdpanel ssd1306spi,P,gp15,gp14,gp13,2 Any Ideas |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10043 |
Are you trying to use two displays on the same SPI pins, or just the 1306? Can you link us to the 1306 module you are using? Many of those 1306 modules can work as either I2C or SPI interface - do you have the correct type, or is it configured for the SPI bus? Just stabbing at ideas for now, but a link to the 1306 LCD panel you are trying to use would be helpful, as they are not all wired up the same way. ![]() Smoke makes things work. When the smoke gets out, it stops! |
Hi I am only using one display the one display at a time. I am actually wanting to replace the ILI9341 with the SSD1306 I purchased two of these SSD1306's and they both arrived configured as SPI I converted one of them to I2C and that works perfectly. However I want to use the I2C for a RTC and hence would rather use SPi for the Display as I have already done using the ILI9341. Pics below |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382 |
It should be possible to get the RTC and display to share I2C, unless the addresses conflict. |
I've used a RTC and a SSD1306I2C display on the same bus on my PicX board design. Works fine, there's no address conflict. :) I've used the same display with both the tiny and bigger RTC modules. Edited 2023-03-20 17:38 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
I would rather keep the SSD1306 on SPI as I already have pcb boards made etc. I am using these on a Raspberry pi pico under mmbasic This is the pinout is have used between the pico and the display. GND >> GND VCC >> VCC (tried 5v and 3.3v) SCLK >> GP18 SDI(MOSI)>>GP19 SDO(MISO) >> GP16 (not used) (Just configured for option system spi) RESET >> GP14 DC >> GP15 CS >> GP13 ps.. If I have no option then how do I setup RTC and Display on I2C If I setup the RTC with option system I2C then I cannot use the grahpic commands on I2C2 as I can't configure both via option system commands. (not that I know of) I am currently iusing GP0,GP1 for the RTC on I2C |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11889 |
Just connect them both to GP0,GP1. With the option SYSTEM I2C set it will all work once you configure OPTION LCDPANEL Sorry haven't got a SPI SSD to test. The code is in there from other ports and did work in the past. Edited 2023-03-20 18:25 by matherp |
I have a 0.96" SSD1306I2C and it works (from 3V3) with: OPTION SYSTEM I2C GP14. GP15 OPTION LCDPANEL SSD1306I2C, RP OPTION RTC AUTO ENABLE Sorry, I've never used the SPI version. I'd assumed that it "Just Worked". I've not spotted anything odd in the setup so far. Edited 2023-03-20 18:54 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thanks Guys for all your help |
