Local Time 04:34 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: PWM - Invalid frequency
Posted: 08:40am 19 Mar 2023
Hi Peter,
I know this used to work, up until very recently, as I was using this frequency (with volume 0) when I needed to play a "rest" on my handheld:
> pwm 2,15.43,0
Error : Invalid frequency
Note that 15.43 Hz is the note below bottom-C.
Obviously I can "fix" my code but:
1. Is there a reason for this limitation ?
2. When was the limitation added ? I could swear it was working one week and then not the next week without my having updated the firmware inbetween - obviously that isn't what happened, but still .
Edited 2023-03-19 18:40 by thwill
Posted: 08:49am 19 Mar 2023
You are running at a greater cpu frequency than before
Posted: 09:01am 19 Mar 2023
Thanks Peter.
You are correct of course and that fixed the problem. I could have sworn I had already tried that already though after I read the source - getting old is no fun, and by the demographics of TBS I'm barely halfway there.
Posted: 11:04am 19 Mar 2023
From the manual.
Minimum frequency = (cpuspeed + 1) / (2^24) Hz. Maximum speed is
OPTION CPUSPEED/4. At very fast speeds the duty cycles will be
increasingly limited.
Posted: 11:08am 19 Mar 2023
Welcome to my world....   ;)
