Local Time 23:44 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : gui touch
stanleyella
Posted: 07:03pm 16 Mar 2023
Hi, sorry to bother you but trying gui area on ili9488 and errors.
The ili9488 touch is calibrated and the touch test works.
I get this error message using gui area 1,2,395,64,14
[17] GUI area 1,2,395,64,14'left button   x  y   w  h
Error : No memory allocated for GUI controls
I spent time reading the latest non vga manual but can't see allocating gui memory.
Also would "loop until pixel px%,py%,1 >0" 'test if next pixel is not black work?
triangle 2,312,66,305,66,319,rgb(yellow),rgb(blue)
gui area 1,2,395,64,14'left button
triangle 192,312,130,305,130,319,rgb(yellow),rgb(blue)
gui area 2,192,395,64,14'right button
triangle 471,2,479,66,464,66,rgb(yellow),rgb(blue)
gui area 3,464,2,14,64'up button
triangle 471,192,479,130,464,130,rgb(yellow),rgb(blue)
gui area 4,464,192,14,64'down button
dim px%=400,py%=int(rnd*200)+60,pdx%=-1,pdy%=0
dim cx%=60,cy%=int(rnd*200)+60,cdx%=-1,cdy%=0
do
 select case touch(ref)
   case 1'left button pressed
     if pdx%=0 then pdy%=0:pdx%=-1:end if
   case 2'right button pressed
     if pdx%=0 then pdy%=0:pdx%=1:end if
   case 3'up button pressed
     if pdy%=0 then pdx%=0:pdy%=-1:end if
   case 4'down button pressed
     if pdy%=0 then pdx%=0:pdy%=1:end if
 end select
 pause 500
 pixel px%,py%,rgb(yellow)'plot new pixel
 px%=px%+pdx%:py%=py%+pdy%
loop until pixel px%,py%,1 >0'test if next pixel is not black
Posted: 07:21pm 16 Mar 2023
Open the manual.
Use the find function to look for text "GUI". Keep Stepping down the file until you find the answer - took me about 10 seconds
Page 51
Posted: 07:32pm 16 Mar 2023
  stanleyella said  Also would "loop until pixel px%,py%,1 >0" 'test if next pixel is not black work?
You're asking about a pixel, so using a FUNCTION, whose return value you want. It would be wise, and may well be mandatory, to use some parentheses.
More thinking, less bashing out code :)
Edited 2023-03-17 05:32 by JohnS
stanleyella
Posted: 07:43pm 16 Mar 2023
why the mmedit error?
pixel x,y,colour simple'' to plot a pixel
pixel x,y,page new.. to read a screen pixel
panky
Posted: 09:56pm 16 Mar 2023
Posted: 11:42pm 16 Mar 2023
  stanleyella said  pixel x,y,page new.. to read a screen pixel
Which page of the manual is that from?
Edited 2023-03-17 09:43 by JohnS
stanleyella
Posted: 02:18am 17 Mar 2023
option gui controls 4 in teraterm seems to have sorted gui controls but says maximum is 3 not 4, so set option gui controls 10.
pixel (x,y) >0 worked. getting there. Now computer opponent... done it before
Bowden_P
Posted: 01:03pm 17 Mar 2023
I was interested to see how/whether Picomite's "GUI AREA" coped with a co-ordinate off-screen in Stanleyella's:-
gui area 1,2,395,,64,14
Admittedly I have a Waveshare ILI9488W screen - 480 x 320 pixels, not stanleyella's exact model, but with :-
Error : 1 is invalid (valid is 1 to 0)
and :-
> option gui controls 2
Error : 395 is invalid (valid is 0 to 320)
Error messaging seems a bit unhappy with the single control !
With best regards, Paul.
p.s. I have PicoMite MMBasic Version 5.07.07b27
Nothing so constant as change.
stanleyella
Posted: 04:05pm 17 Mar 2023
Hi Pual. the same error , it was a typo.
touch seems to like fingernails more than finger prints,
touch supposed to be NOT like a phone touch screen.
my first try on ili9488. maybe ili9341 better, will try
gui area 1,1,295,64,16
gui area 2,128,295,64,16
gui area 3,464,2,16,64
gui area 4,464,130,16,64
Posted: 05:04pm 17 Mar 2023
Touch on all the LCD displays supported by MMBasic is resistive, not capacitive. That's why you find it works better with fingernals than a finger. The bast way to use these displays is with a stylus (they are often supplied with one).
When you want to test an area of the screen it's better to test for the X and Y edges of that rather than for a point. The GUI commands take this into account.
stanleyella
Posted: 05:36pm 17 Mar 2023
Thanks all for helping me. I did read the manual but didn't get gui controls relevance
my simple tron
'tron ili9488
OPTION EXPLICIT
OPTION DEFAULT NONE
cls
box 0,0,463,303,1,rgb(white),rgb(black)
dim ts%
ts%=int(rnd*200)+60
triangle 0,ts%,12,ts%+8,0,ts%+16,rgb(White)
ts%=int(rnd*200)+60
triangle 461,ts%,449,ts%+8,461,ts%+16,rgb(White)
ts%=int(rnd*360)+60
triangle ts%,0,ts%+8,10,ts%+16,0,rgb(White)
ts%=int(rnd*360)+60
triangle ts%,303,ts%+8,293,ts%+16,303,rgb(White)
dim cx%=60,cy%=int(rnd*200)+60,cdx%=1,cdy%=0
do
 if pixel (px%,py%) >0 then end
 if TOUCH(REF) >0 then 'check user button pressed
     case 1 'left
     case 2 'right
     case 3 'up
     case 4 'down
   end select
 end if
 'computer move
 if cdx%=-1 then
   if pixel (cx%-1,cy%) >0 then
     cdx%=0
     if py%>cy% then
       cdy%=1
     else
       cdy%=-1
     end if
   end if
 else if cdx%=1 then
   if pixel (cx%+1,cy%) >0 then
     cdx%=0
     if py%>cy% then
       cdy%=1
     else
       cdy%=-1
     end if
   end if
 else if cdy%=-1 then
   if pixel (cx%,cy%-1) >0 then
     cdy%=0
     if px%>cx% then
       cdx%=1
     else
       cdx%=-1
     end if
   end if
 else if cdy%=1 then
   if pixel (cx%,cy%+1) >0 then
     cdy%=0
     if px%>cx% then
       cdx%=1
     else
       cdx%=-1
     end if
   end if
 end if
 cx%=cx%+cdx%:cy%=cy%+cdy%
 if pixel (cx%,cy%) >0 then end
 pixel cx%,cy%,rgb(cyan)
 pause 50
loop
vegipete
Posted: 06:22pm 17 Mar 2023
Looks fun...
Because I can't help compressing code:
  ' computer move
  if cdx% then   ' moving in x direction
    if pixel(cx%+cdx%) then  ' move blocked
      cdx% = 0
      cdy% = -1 + 2 * (py% > cy%)  ' turn toward player
    endif
  else           ' moving in y direction
    if pixel(cy%+cdy%) then  ' move blocked
      cdy% = 0
      cdx% = -1 + 2 * (px% > cx%)  ' turn toward player
    endif
  endif
  if pixel(cx%,cy%) > 0 then end   ' computer can't move!
stanleyella
Posted: 09:06pm 17 Mar 2023
working on another algo
I thought pixel needed x,y
"if pixel(cx%+cdx%) then ' move blocked" ?
pixel plotting page 111
pixel reading page 135
vegipete
Posted: 09:21pm 17 Mar 2023
You are right. I was sloppy. Should be:
if pixel(cx%+cdx%,cy%) then  ' move blocked
and
if pixel(cx%,cy%+cdy%) then  ' move blocked
paceman
Posted: 11:20am 18 Mar 2023
Just tried this using version b25 but it doesn't like GUI CONTROLS 4, it needs GUI CONTROLS 5 for some reason.
> run
[17] GUI area 1,1,295,64,16
> run
[23] GUI area 4,464,130,16,64
Error : 4 is invalid (valid is 1 to 3)
> option list
PicoMite MMBasic Version 5.07.07b25
OPTION SYSTEM SPI GP18,GP19,GP20
OPTION SYSTEM I2C GP0,GP1
OPTION COLOURCODE ON
OPTION DISPLAY 40, 100
OPTION LCDPANEL ILI9488, RLANDSCAPE,GP26,GP27,GP28
OPTION GUI CONTROLS 4
OPTION TOUCH GP22,GP21,GP5
GUI CALIBRATE 0, 254, 139, 1289, 841
OPTION SDCARD GP3
> option gui controls 5
> RUN
> RUN  ' running fine from here
Posted: 11:47am 18 Mar 2023
As the amount of RAM used for GUI CONTROLS is rounded up to 2048 bytes anyway there's no point in specifying such low numbers. One control will require 2048 bytes as will 39 controls (39*52=2028 bytes). 40 controls will require 4096 bytes of RAM.
stanleyella
Posted: 02:57pm 18 Mar 2023
@paceman That's the error I got. I thought the gui controls started at zero but don't.
Mick- thanks for clearing that up.
It's in the manual but option gui controls isn't really mentioned and the number of gui controls could be better explained imho. pixel page 111 and 135,why not same page?
This is my first touch test and seems I'm not the only one who found it not as easy as it looks. I didn't want to ask the forum but I was getting errors I couldn't resolve.
I can see why mechanical buttons are used and has anyone tried using resistors and buttons and one a-d input pin? Each button giving a different voltage when pressed.
cheers, stan.
Edited 2023-03-19 01:02 by stanleyella
Posted: 03:02pm 18 Mar 2023
In most cases I've had no problems with the Gui controls. They can get a bit awkward if you start to try to do odd things, but most of the time I've found them to be very good indeed. You do need to have a good play to get the most out of them. Above all, remember that when you use them everything is controlled by the user, not by your program. You mustn't go doing things that the user hasn't requested or you can get into an awful knot.
Edited 2023-03-19 01:05 by Mixtel90
stanleyella
Posted: 06:20pm 18 Mar 2023
Hi Mick. I noticed cls after gui area disables them,  probably says so somewhere.
As you can't re dim or define gui area only once, I stuck it all at the start so I could restart the game in code and found moving cls after gui area disabled it. How to restart the game and use cls?
dim px%,py%,pdx%,pdy%
dim cx%,cy%,cdx%,cdy%
dim ts%,tr%
cls 'works here
gui area 1,1,295,64,16 'left button
gui area 2,128,295,64,16 'right button
gui area 3,464,2,16,64 'up button
gui area 4,464,130,16,64 'down button
'start
'cls 'disables gui area here
Posted: 06:35pm 18 Mar 2023
Do you need to CLS? Can you use GUI HIDE to hide all GUI controls and GUI SHOW to bring them back?
You can also use GUI REDRAW if the screen has become corrupted.
Then GUI SETUP n can set up controls on page n and you can swap them any time with GUI PAGE n.
