Local Time 23:51 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Making Custom Characters on 16X2 LCD
cosmic frog
Posted: 10:59am 15 Mar 2023
Making Custom Graphics on 1602/2004 LCD
This will work on HD44780 KS0066 SPLC780 controller chips that have 1,2 or 4 lines of text.
The characters are made on a 5X8 grid.
Here is a custom character of a Bell.
 16 8 4 2 1
1      *     =4
2    * * *   =14(8+4+2=14)
3    * * *   =14
4    * * *   =14
5  * * * * * =31(16+8+4+2+1=31)
6            =0
7      *     =4
8            =0
There are 8 custom characters.
CHR$(0) has the command LCD CMD 64
CHR$(1) has the command LCD CMD 72
CHR$(2) has the command LCD CMD 80
CHR$(3) has the command LCD CMD 88
CHR$(4) has the command LCD CMD 96
CHR$(5) has the command LCD CMD 104
CHR$(6) has the command LCD CMD 112
CHR$(7) has the command LCD CMD 120
So to print the Bell character above use-
LCD CMD 64 : LCD DATA 4,14,14,14,31,0,4,0
LCD 1,1,CHR$(0)
To Print another custom character just use the next CHR$-
LCD CMD 72 : LCD DATA X,X,X,X,X,X,X,X
LCD 1,2,CHR$(1)
Remember if you are using the PicoMite to use BITBANG LCD.
Dave.
Posted: 01:16pm 15 Mar 2023
worth adding, you only need to do
once, (e.g. in the preamble) not each time you do the
LCD 1,1,CHR$(0)
jus' sayin'
Edited 2023-03-15 23:19 by CaptainBoing
cosmic frog
Posted: 01:26pm 15 Mar 2023
  CaptainBoing said  worth adding, you only need to do
LCD 1,1,CHR$(0)
jus' sayin'
Good point.
