Local Time 00:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Non-printable and Delimiters in MMBasic string / DATA statement
Mark
Posted: 01:53pm 08 Mar 2023
Is the only way to include non-printable characters, such as TAB and the QUOTE delimiter in a MMBasic string constant with CHR$() and concatenation?
CONST S$ = CHR$(9) + "Preceded by TAB and followed by Quote." + CHR$(34)
It appears that the + concatenation doesn't work in DATA statements. Only the part up to the first + is READ.
Thanks,
Mark
Posted: 02:39pm 08 Mar 2023
Hi Mark,
If memory serves correctly then this is a known limitation; the syntax of DATA is a bit "iffy" and doesn't evaluate string expressions, something about a need to support unquoted strings in DATA statements for backward compatibility with earlier BASIC dialects.
What I have done previously is use some combination of printable characters in the DATA and then process the strings as I read them out of the DATA section to replace with the desired non-printable characters.
Edited 2023-03-09 00:41 by thwill
Posted: 02:41pm 08 Mar 2023
That's correct. You can't have a non-printable character on screen because it's non-printable. :)  (This is actually a lie. You can PRINT CHR$(240) for example.)
Your example works ok for me.
PicoMiteVGA MMBasic Version 5.07.07b20
> ? s$
You can also do silly stuff like:
> a$=" an experiment "
> poke var a$,1,9
> poke var a$,15,34
> ? a$
       an experiment"
DATA statements are a different thing.
They store:
- unquoted text under certain conditions.
- quoted text.
- numeric values.
- numeric expressions.
They don't store string expressions.
Edited 2023-03-09 00:51 by Mixtel90
Posted: 03:08pm 08 Mar 2023
DATA statements can be made dynamic with the use of a variable.
try the following
Dim Integer aa=222,n,x
Data 1,aa,3
for n=1 to 3:read x:Print x:next
Very nice.
Unfortunately, this is confined to numeric varables:
Dim s$="fred",x$
Data "!",s$,"3"
for n=1 to 3:read x$:Print x$:next
treats the data s$ as the literal characters s and $
As an aside, String CONSTants don't need to be explicitly typed e.g. when DIMing variables, the explicit type can be omitted if basic sees the type coming so
Dim String s="fred"
is fine, but
Dim s="fred" throws an error
counter-intuitively,
Const e=Chr$(27)+"["
is fine and e is used as a string of characters with no explicit type (i.e. e$)
Edited 2023-03-09 01:13 by CaptainBoing
Posted: 03:11pm 08 Mar 2023
That'd the nice thing about standards. There are so many to choose from. :)
