Local Time 05:01 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Spirograph random colours
asknik2022
Posted: 05:08pm 03 Mar 2023
OPTION BASE 1
'Define color lookup table
DIM rgb%(4,3)
rgb%(1,1)=255: rgb%(1,2)=255: rgb%(1,3)=0 'YELLOW
rgb%(2,1)=255: rgb%(2,2)=0: rgb%(2,3)=0 'RED
rgb%(3,1)=0: rgb%(3,2)=0: rgb%(3,3)=255 'BLUE
rgb%(4,1)=0: rgb%(4,2)=128: rgb%(4,3)=0 'GREEN
'Set up the Spirograph parameters
r1 = 90
r2 = 30
p = 60
colorindex =0
'Set up the rotation parameters
cx = 120
cy = 160
angle = 0
angle_step = 0.5
CLS
DO
   getcol
   sa = SIN(angle)
   ca = COS(angle)
   'Calculate the Spirograph path
   FOR t = 0 TO 360 STEP 1
       a = (r1-r2)/r2
       x = (r1-r2)*COS(t) + p*COS(a*t)
       y = (r1-r2)*SIN(t) - p*SIN(a*t)
       'Rotate the coordinates and draw a pixel
       xp = cx + INT(x*ca - y*sa)
       yp = cy + INT(x*sa + y*ca)
       Pixel xp,yp,rgb(rgb%(colorindex,1),rgb%(colorindex,2),rgb%(colorindex,3))
   NEXT t
   ' Update the angle and wait a bit before redrawing
   angle = angle + angle_step
LOOP
sub getcol
' Set color
colorindex=int(rnd*3)+1
end sub
homa
Posted: 08:36pm 03 Mar 2023
cx = 120
cy = 160
switch to
cy = 120
cx = 160
and add at the beginning
mode 2
Edited 2023-03-04 06:38 by homa
asknik2022
Posted: 08:04am 04 Mar 2023
This is for the picomite and the screen was set to portrait ili9341
homa
Posted: 11:26am 04 Mar 2023
  asknik2022 said  This is for the picomite and the screen was set to portrait ili9341
Ah, sorry. I use the PicoMiteVGA.
Andrew_G
Posted: 05:22am 05 Mar 2023
@asknik,
G'day and a belated "welcome" to the forum.
A nice program, thanks. It is one of those things I enjoyed in my youth and it is good to now see it in MMBasic.
I've fiddled with r1 & r2 (as well as Cx and Cy).
I'll add it to the programs for my grandchildren.
Cheers,
Andrew
