Local Time 00:22 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI CALIBRATE value
Posted: 07:58pm 24 Feb 2023
Doing
GUI CALIBRATE
Done. No errors
Deviation X = -2, Y = -2147483648 (pixels)
Is the Y value OK?
This is PicoMite (non-VGA) V5.07.06 with the Boat computer hardware.
Displayed items seem where they should be so all in practice looks good...
Edited 2023-02-25 06:09 by JohnS
Posted: 09:27pm 24 Feb 2023
No Errors is the bit that matters, Deviation is just information about the difference between your unit and the prototype.
Each time you calibrate you usually get slightly different deviations, as it is difficult to touch with one pixel accuracy. Parallax adds more unless your line of sight is exactly perpendicular to the screen. Manufacturing tolerances also contribute.
As long as it looks right it is right.
Posted: 01:12am 25 Feb 2023
In Hex the y value is FFFF FFFF 8000 000
That looks "interesting"
Posted: 02:42am 25 Feb 2023
Internally the calibration error is a 32-bit signed integer and it looks like the PicoMite firmware tried to convert it to a 64-bit integer for display (and did not succeed).
This is not important, as Phil said "No Errors is the bit that matters".
Posted: 07:55am 25 Feb 2023
No worries. Thanks.
