Local Time 00:22 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Re PicoMite Text and Number Boxes
LouisG
Posted: 06:18am 22 Feb 2023
I made a number box on an ILI9488 screen showing the setpoint for a timer. It works fine and displays a value from an element in an array. Am able to touch the number box, have a number pad pop up, update the setpoint by punching in a new number and pressing Enter on the number pad.
However, it doesn't permanently replace the old value of the array element with the new value. It just updates the value shown in the number box (which is marvellous in itself). Is there a way to make the update permanent, i.e. update the array element?
...Louis
Posted: 07:21am 22 Feb 2023
See if this works:-
A(n) = CtrlVal(#x)
where x is the number of the control.
Haven't tried it but the manual seems to show that on p62.
"= CTRLVAL(#ref)
This is a function that will return the current value of a control. For controls like check boxes or switches it
will be the number one (true) indicating that the control has been selected by the user or zero (false) if not.
For controls that hold a number (e.g. a SPINBOX) the value will be the number (normally a floating point
number). For controls that hold a string (e.g. TEXTBOX) the value will be a string. For example:
PRINT "The number in the spin box is: " CTRLVAL(#10)"
Edited 2023-02-22 17:25 by phil99
Posted: 08:43am 22 Feb 2023
As Phil commented, you have to read the new value of the control and assign it to your variable... there is no facility to automatically update a variable.
If you want to automate this update you could intercept the touch up interrupt and copy the value in the interrupt.  This will work because the touch up interrupt is fired after the user has touched the ENT key and closed the number box.  By the way, in most cases you do not have to copy the value to somewhere else, you can just use the value of the control directly.  ie, IF CTRLVAL(#10) > 123 THEN do something.
LouisG
Posted: 09:58am 22 Feb 2023
Thanks Guys.
Will give Touch Up a go + assign CTRLVAL to the variable.
